Looking to lift Gen 2 any suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neuarmy, Feb 6, 2016.
  1. Feb 6, 2016 at 1:40 AM
    Neuarmy
    Neuarmy [OP] New Member
    Andrew
    08 tacoma 4x4
    None yet
    Looking to lift my 08 toyota tacoma don't want anything really big and out there just want enough to go throw the backwoods and down by the river any suggestions on that wheels, tires and brand of lift kits
  2. Feb 6, 2016 at 2:20 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Probably stick with a 3" lift maximum for what you described. Avoid spacers and blocks.
    Wheels either your stock wheels + wheel spacers or new wheels with a backspace of 4.5" or less (helps with clearance)
    Tires really just need more info on what terrain ect.. But probably a 33" tire if you don't mind a little plastic trimming
  3. Feb 6, 2016 at 3:03 AM
    Neuarmy
    Andrew
    08 tacoma 4x4
    None yet
    Would 6 inch be to much with 37s it's rocky terrain with streams and mature woods mostly thick mud with rocks everywhere
  4. Feb 6, 2016 at 4:12 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Are you trolling? Your 1st post said " don't want anything big" and then you throw out 6" w/37's??
    JimboAnz likes this.
  5. Feb 6, 2016 at 5:50 AM
    Neuarmy
    Andrew
    08 tacoma 4x4
    None yet
    I mean I don't want a 8 to 12 inche lift
  6. Feb 6, 2016 at 6:06 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    (THIS)
  7. Feb 6, 2016 at 10:22 AM
    Blacktacoma23
    2011 Mall Crawler
    Ok so don't buy a Bulletproof 12" lift haha
    You have to ask yourself if you want a drop bracket, which means cutting out part of your cross member (no turning back unless you have a pre runner, in which case you want new spindles for that large of a lift not a DB)
  8. Feb 6, 2016 at 10:34 AM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    the picture you show looks like a 3" lift...which would be just fine for what you are looking for, tires can be 285's with no trimming needed, based on what wheels you use.
