Looking to lift my 2001 Tacoma TRD SR5
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jeff Brown, Jun 23, 2015.
  1. Jun 23, 2015 at 9:44 AM
    Jeff Brown
    Jeff Brown [OP] Jmoney
    Rolla, Mo
    Toyota Tacoma 2001 TRD Offroad 4X4 SR5
    I am looking for some help with lifting my Tacoma. I would like to put 285/75/16 tires on it. How much should I lift my truck to make this happen? Will I need to do any trimming? Suggestions on what kind of lift? Any help greatly appreciated. New Tacoma owner here. Thanks!
  2. Jun 23, 2015 at 9:47 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    at least 2.5 in lift. You will need to do the pinch weld mod. Not much trimming just hammering.
  3. Jun 24, 2015 at 1:40 PM
    Soccerdallin
    Soccerdallin Well-Known Member
    Dallin
    Arizona
    04 SR5 3.4L V6 4X4
    Magnaflow exhaust w/ tip, 18" Rockstars, AEM CAI, TB Spacer, Billet Grille, Limo tint, LED tail lights, 20,000k HID headlights + Blue LED strips, debadged, Jl Audio Subs in custom box, 6X8 speakers with tweeters, sony deck.
    I'm also looking for a little lift, like usual without breaking the bank o_O gotta get rid of that rub!
  4. Jun 25, 2015 at 7:42 AM
    Jeff Brown
    Rolla, Mo
    A local shop quoted me $1800. I feel like that isn't a bad deal because it includes tires, wheels, and a Rough Country 2.5 inch lift. I would like to stay under $2000. They said with that lift I will be able to fit 31X10.50 tires on it.
  5. Jun 25, 2015 at 7:54 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    You can run that size tires stock I believe. I ran 265/75r16 stock which is roughly 31x10.5. If you're able to do the work yourself you can get a good lift for $1800. But if you want tires too, a good way to go would be OME and tires but you'll have stock wheels.
  6. Jun 25, 2015 at 12:19 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    31x10.5 = 265/70, stock size on 98+ 4wd/pre-runner
    32x10.5 = 265/75, fits with very little rub (full lock or off-road)
    33x12.5 = 285/75, read above
    also, there are a ton of threads already and user/build pages to look at and see which one you like. search under the 1st Gen forums and you will read for weeks ;p
  7. Jun 25, 2015 at 12:27 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I'm guessing the rough country lift they are talking about is the 2.5" spacer/shackle lift that runs about $250+ shipping. Believe it or not I had that lift and used it for about 8 years... and loved it! (for the money). It was surprisingly effective and you can fit 32" tires. You can fit 33" tires if you do some pinch weld mods, and you may still have just a slight rub in very odd circumstances. 31s are too small. The lift itself is not difficult to install.
    What kind of tires? I'd get a quality all terrain and skip the wheels for now if money is tight. Good tires in the 32" range will run you $800-$900 out the door, give or take.
  8. Jun 26, 2015 at 7:34 AM
    Jeff Brown
    Rolla, Mo
    @Buckoma Yeah they said it was the 2.5" spacer and shackle lift. I am thinking about the Pro Comp Mud terrain tires. The shop said I could get those for about $210 a piece. Thanks for the advice everyone!
  9. Jun 26, 2015 at 9:31 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
  10. Jun 26, 2015 at 9:54 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    a 285 is only 11.25" wide btw and u can do 5100 upfront but with stock coils (since u have the OR pkgs) u can only go with the 1.25" upfront, if u want 2.5" u can get eibach coils for $170 and a rear shackle lift for less than $100, my buddy with a first gen went this route, didnt get 5100 on the rear just up front, and it was just over $400 i think, i helped him with the install and it took both of us about 3 hours or so for all of it. he has 265/75r 16 no rub and says the ride is great
  11. Jun 29, 2015 at 7:30 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    thanks E.J. I erred on the side of caution but didn't figure it out. :p I'm guessing a 305 would put it at ~12.5 then (40mm = 1.6 inch)
    yota243 likes this.
