Looking to lift & upgrade tires, info appreciated
Discussion in 'Suspension' started by oldcorps, Jun 6, 2010.
  1. Jun 6, 2010 at 3:56 PM
    oldcorps
    oldcorps [OP] Member
    Bryan
    Long Island NY.
    08 TRD sport 4x4 SR5
    K&N repl air filter OEM steps
    Hi, just looking for some info on a lift kit and tires. looking to put a 2-3 inch lift on my 08 trd 4x4 dbl cab longbed. does anyone have any info on if i put dueller at 285/70/r17 on stock rims what is the least amount of lift i need? im really looking to keep stock bilsteins on, i mostly drive hwy and beach offroad. oh and would i need and rear blocks or leafs, the truck has about a 2" rake to it. if so which is better? thanks, this thread has alot of knowledgable people and grat tacos.
  2. Jun 6, 2010 at 4:01 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I just installed a set of OME front springs and all four shocks.
    Worth it to spend a bit more now than figure out you will need it later and have to get another alignment.
    Rear I went with an AAL to lift it just a bit.
    Can't help with wheels and tires yet I am still stock there.
  3. Jun 6, 2010 at 4:08 PM
    rick
    rick `
    welcome to tacomaworld Bryan. you will need spacers with the stock rims for that size tire. as far as suspension. imo the Bilstein 5100s should be sufficient if set on the middle notch
  4. Jun 6, 2010 at 4:16 PM
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    I rolled with an OME 3" lift with 265/75/16 BFG at/ko E series. Its fairly cheap and easy to install. Or you could go with Bilstien 5100's all around and an AAL..
  5. Jun 6, 2010 at 4:22 PM
    callahansd
    callahansd Guest
    if price is an issue as it was with me, just get a 2 or 3 inch spacer kit w/add a leaf (like i did), unless you plan on taking it off road a lot, then go with the new coils, i have 285/70/17 on stock rims and a 1/4 inch wheel spacer, even with the spacer iv lost about 10-15% of my turning, they only rub on the stock UCA, the Stock UCA will also make it impossible to align it all the way, Im saving up for new control arms now, you'll have to get them eventually but until then I just rotate and balance regularly. Do your homework before buying anything!
  6. Jun 6, 2010 at 5:44 PM
    oldcorps
    Bryan
    Long Island NY.
    thanks guys, if i just got the 5100s, i could use the stock coils correct? would i still need aal or could i stay stock in the rear?
  7. Jun 6, 2010 at 6:13 PM
    rick
    rick `
    yes you can use the stock coils. and yes you can stay stock in the rear.
  8. Jun 6, 2010 at 7:35 PM
    oldcorps
    Bryan
    Long Island NY.
    thanks rick, i looked up the 5100s and looks like the best option, if i go 285/65/17 do i still need spacers? or even better with stock rims whats the largest tire i can go?
    ps. took a look at your picks , sweet ride,clean look,tastefully done.thanks again.
  9. Jun 7, 2010 at 3:06 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Welcome the 5100s are adjustable. You would need to set them at 2.5". You might also need a 1 and 1/2" or 2" AAL for the rear. At 2.5 you will clear 285s, but will need wheel spacers for stock rims; Probably 1.25" Spidertrax. This is what I'm doing to mine in the near furture
