Looking to purchase Tacoma S Runner
Discussion in '1st Gen. Tacomas (1995-2004)' started by RACERX167, Oct 4, 2013.
  1. Oct 4, 2013 at 7:06 PM
    RACERX167
    RACERX167 [OP] Member
    Fritz
    Ohio
    04 TRD Pre-Runner 3.4
    I currently have a 2004 TRD Tacoma Pre-Runner V-6 but am looking to add something a little sportier to the stable. With that being said, I was wondering if anyone knew where I could find a solid Tacoma S-Runner at? I am open to normally aspirated or supercharged applications? However, I can't emphasize enough that I don't want something that has been thrashed on its whole life. Just a nice, solid, well cared fro and maintained S-Runner.
    Please let me know what you have and if it is easier feel free to email me @ mx4life167@hotmail.com with info.
    I truly appreciate the help!!
    Rob Polz
  2. Oct 4, 2013 at 7:56 PM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    S runner is correct dont know much. But there rare and colormatched. so if its red even the grill is red
  3. Oct 4, 2013 at 8:20 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    I think S Runners are supercharged from the factory I believe.
    Are you looking specifically for an S Runner or a good 5 lug build?
  4. Oct 4, 2013 at 8:28 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    There was not very many produced - shit, I've only ever seen half a dozen in person...
    The S Runner is essentially the 1st gen X Runner and IIR they did not come factory with the s/c for the 3.4 but it could be added.
  5. Oct 4, 2013 at 11:05 PM
    RACERX167
    Fritz
    Ohio
    From 2001-2004 Toyota produced the "S-Runner" model in limited numbers. It is based off the 2WD extended cab Tacoma. Toyota then added the 5VZ-FE V-6 engine and a "5 speed only" manual transmission as well as a bunch of other mods that are exclusive to this model only and call it the "S-Runner". Alot of guys that own these trucks put on the 3.4L TRD supercharger that is available through Toyota. That is why I stated that I am looking for one that is either supercharged or normally aspirated.
    From 2005-2013 Toyota produced the "X-Runner" which is basically the same style platform as mentioned above, but comes with the 4.0 liter engine and "6 speed only" transmission. Toyota's TRD 4.0 liter supercharger will also fit this model. Sadly, Toyota has discontinued this model for 2014.
    Just a little history for you guys that were trying to guess what exactly I was referring to. I have driven both of these trucks in both applications and because of the lower center of gravity and minimal power to weight ratio are just a BLAST to drive!! If you would like, do some research for yourselves and check out some of the TRD supercharged X-Runner videos on You Tube. Some of the numbers these little trucks are putting up are quite impresive to say the least.
    Enjoy!!
  6. Oct 5, 2013 at 5:44 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I've been looking for a non thrashed one myself for a while. There's a couple on adhuntr, but all look beat or far, far away. Go luck on your search.
  7. Oct 6, 2013 at 7:30 PM
    RACERX167
    Fritz
    Ohio
    I am not familiar with ad hunter? Can you please educate me a bit. I don't mind the drive if it is worth it?
    Thanks
  8. Oct 7, 2013 at 6:19 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
  9. Oct 7, 2013 at 7:31 AM
    Aquatic Tacoma
    Odessa, Fl.
    Adhuntr.com = It's a search site that lets you search the whole country at once using multiple websites such as craigslist.com from one search box.
  10. Jun 25, 2014 at 8:39 PM
    tacomadude1212
    tacomadude1212 Member
    virginia
    2001 Toyota Tacoma S-Runner Ext CAB V6, 5 speed, well maintained, with 98,000 miles. Comes with power door locks and windows, am-fm cd player, power seat. Has recent fluids changed with Mobile one synthetic, new belts,new timing belt and water pump, and tune-up with NGK iridium plugs and wires. gets excellent gas mileage Toyota lowered a 4x2 X-cab pickup truck by an inch and fitted performance-minded Tokico gas shocks. Toyota other suspension mods include increased-rate springs, front and rear anti-sway bars, Toyota's 3.4L/190-hp DOHC V-6 is bolted to a five-speed manual gearbox.
    I have a S-runner that's in excellent condition for sale
