Looking to put on a lift for bigger tires..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by esalas, Nov 1, 2010.
  1. Nov 1, 2010 at 2:53 PM
    esalas
    esalas [OP] esalas
    Eddie
    San Francisco
    2010 Toyota Tacoma TRD Sport
    Smitty Built step bars, K&N Cold Air intake, Extang Tonneau cover. Toytec 3" lift. Pro comp wheels and all terrains
    I own a 2010 Tacoma TRD Sport.. and am looking to put on a 3 to 4 inch lift for extra clearance before hitting the trails... Just was wondering what other people out there would recommend?
  2. Nov 1, 2010 at 2:57 PM
    Special_K
    Special_K o_o
    Eddie
    Alameda, CA
    2014 Subaru STI hatchback
    Tuned by Snail Performance, 305WHP/350TQ on E85, Corsa Pro Series black tip CBE, Perrin CAI, Perrin ELH, Invidia catless DP, ID1000 injectors, Turbosmart Dual Port BOV, Turbosmart IWG Actuator, Cobb FPR, Perrin motor and tranny mounts, Moroso dual catch cans, Cobb AP V3, Grimmspeed turbo heatshield, Grimmspeed EBCS, Perrin pitchstop mount, Kartboy bushings, battery tiedown, oil cap, Perrin reverse lockout leaver, Hella Supertones horns, GT-Spec flat bottom steering wheel, Rally Armor mudflaps, Pioneer 4600BT HU, JL Audio door speakers, sub, and amp, Weathertech floormats, Grimmspeed LWCP, Perrin front license plate delete and relocator, Perrin alternator and radiator shrouds, Grimmspeed master cylinder brace, TWM Gunmetal M1 Abrams shift knob, Defi boost and oil pressure gauges, SMY Clustermaker dual gaugepod, JDM black side badges, Greddy magnetic oil drain plug
    whats up welcome to TW, just throw that in to the "search" at the top and all kinds of stuff will pop up for what you are looking for on your truck. I've got the Icon stage 3 on my truck and it's awesome.
    What unit are you at up there?
  3. Nov 1, 2010 at 3:00 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x100^^^^^^^^^^^^^
    im running 5100's and an 2" aal
  4. Nov 1, 2010 at 3:12 PM
    KauaiSandRambler
    KauaiSandRambler Member
    Chad
    Kauai
    07 Tacoma TRD 4x4
    Start searching and do your homework. The last thing you wanna do to your new truck is put on a lift you're unhappy with. Top lifts here seem to be toytech, bilstein 5100 adjustable shocks with an add a leaf, a lot of unhappy folks with spacers and blocks. Im not sure if the 2010's apply but also look into getting your TSB springs done. I just put on some bilstein 5100's with an add a leaf for the rear, its definately the lift of choice for a <3" lift. Little bit bigger tires will fit but lot of scary stories of 33"s rubbing without wheel spacers and some trimming. Start searching threads... bet you will do a lot more than a lift after a few weeks on this site.
