Looking to put on bigger tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob1249, Feb 17, 2017.
  1. Feb 17, 2017 at 9:40 AM
    rob1249
    rob1249 [OP] New Member
    Robert
    Central New York
    2008 tacoma
    Hi, I have a 2008 Tacoma and I recently installed the Rancho quick lift shocks, they advertise that I can increase two tire sizes. The original size is 245,75,16. Is 265,75,16 two sizes bigger? And if so has anyone put the 265,75,16 on their factory toyota rims? And did the 265's fit on and clear? My concern is the clearance between the tire side wall and the upper A arm/upper ball joint area. There just dosn't look like much room and the 265's are just under a inch widder. I'm afraid they will hit the upper A arm. Dose any one have any experience with this or any suggestions?
  2. Feb 17, 2017 at 10:52 AM
    tomrtrd
    tomrtrd Member
    tom
    06 Tacoma 4X4
    ALARM @ REMOTE START, 2" LEVELING LIFT
    They will fit , depends on the lift you may need to take off the front mud flaps.
  3. Feb 17, 2017 at 11:00 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Agree they should fit fine!i have 285 75 16 and did minor trimming and mud flap removal. Also bmc just to be on the safe side.
