looking to quiet down/remove rasp from 4cyl exhaust
Discussion in '4 Cylinder' started by Jim511, Oct 1, 2017.
  1. Oct 1, 2017 at 11:07 AM
    Jim511
    Jim511 [OP] Member
    2016 Tacoma SR
    Truck is a 2016 access cab. I know that the stock truck is already rather quiet, but I'm pretty particular in exhaust noise as I can't stand raspiness and rattles. Yes its a truck I understand that, but I think there could be some improvements.
    So I was wondering if anyone has done any work as far as resonators and new mufflers to remove some of the annoying sounds. Plus I feel like removing the extremely large muffler would help out. Thanks
  2. Oct 1, 2017 at 11:09 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    The rattles have more to do with how the exhaust is mounted... the rasp you can change but know that if you restrict it more you will be making the engine work harder
  3. Oct 1, 2017 at 11:12 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    dynamat the interior and heat wrap the exhaust
    should help deaden some sound i imagine
    sounds are vibrations, control the vibrations control the sounds
  4. Oct 1, 2017 at 11:13 AM
    t3mpo
    t3mpo Well-Known Member
    Jose
    2016 Tacoma SR
    I’m assuming you have the stock muffler. I actually had a flowmaster delta 50 and hated it. Went back to the stock and seems fine now. Never really had gave some thought to make it quieter. It’s a big 4 cylinder. My old v6 was the same size so not sure if there’s anything you could do to lower the sound.
    You can install the LCE header and not have to rev up to 4K to get the same power so maybe that would help? Doesn’t hurt to have the extra power either.
  5. Oct 1, 2017 at 11:14 AM
    t3mpo
    Jose
    2016 Tacoma SR
    True but it would make it heavier and costly. I like the exhaust wrap option
  6. Oct 2, 2017 at 1:37 PM
    Jim511
    Jim511 [OP] Member
    2016 Tacoma SR
    I was thinking about wrapping it as I used to have wrap on my subaru's borla header due to it being thin wall tubing and that got rid of the tin sound it produced. I just wasn't sure if anyone had messed around with a different variation of muffler and resonator setup. Thanks for the suggestions, I'll look into some changes
  7. Oct 2, 2017 at 5:48 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Speedytech7 and Jim511[OP] like this.
  8. Oct 2, 2017 at 6:10 PM
    Jim511
    Jim511 [OP] Member
    2016 Tacoma SR
    I legit had that exact resonator on my subaru's midpipe and it made the exhaust that much better, hence the reason I brought up this thread! I actually still have my exhaust from that car and contemplated cutting and making it work as it is a 2.25" exhaust so it would all work. I just don't want my truck to sound like an import car, hence why I'm not 100% set on going into a full exhaust & headers
  9. Oct 2, 2017 at 6:20 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I wanted the extra power, so I'm running the LCE header and LCE catback exhaust. Originally, I was going to go with the Magnaflow catback. It was out of stock when I ordered, so I went with the LCE. It still uses a Magnaflow muffler. The cat pipe is the only stock part of my exhaust.
    I wouldn't say that my truck sounds like an import car, but the setup when I first put it on was just too loud and it droned at 70+. I'd get headaches after driving 1.5 - 2 hours. I put in the resonator hoping that it would tame the exhaust, which thankfully it did.
    TheCookieMonster likes this.
  10. Oct 4, 2017 at 3:35 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Removing the muffler will not make your truck quieter.
  11. Oct 5, 2017 at 4:39 AM
    Jim511
    Jim511 [OP] Member
    2016 Tacoma SR
    Without you informing me of this, I never would have known. Thank you!
    7r41lbr34k3r likes this.
  12. Oct 13, 2017 at 11:24 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    OEM Toyota muffler and a resonator placed under the cab. Vibrant performance has a stainless steel resonator that can be installed before the muffler that should fit your needs. Just be sure you know the pipe size. FYI Toyota pipes are stainless steel. I am not certain if they are 304/316 or the common 409 stainless. 409 stainless rusts after roughly 10 years.
  13. Apr 6, 2018 at 8:10 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    Hey I’m in a similar position. My 2.7 with magnaflow muffler sounds a bit ricey at high rpms and has a drone on the highway between 65-75. I like the idea of trying a resonator but I’m afraid it will add to much resistance to the exhaust flow, making my engine work harder. Have you and any issues with your setup or ever hear of this? Thanks
  14. Apr 7, 2018 at 6:21 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    A straight through resonator should add little to no add exhaust flow restriction. They're a perforated pipe on the inside with some sound absorbing material packed around it and the outer body.
  15. Apr 7, 2018 at 1:03 PM
    iamroddy
    iamroddy Well-Known Member
  16. Apr 9, 2018 at 4:52 PM
    Flowmaster Exhaust
    Flowmaster Exhaust Well-Known Member
    Flowmaster
    As others have stated, the addition of a resonator to your exhaust system will help to rid your Tacoma of the drone that you're experiencing. We offer a number of muffler and resonator solutions for nearly any vehicle. Please give us a call at 707-544-4761 and our Support Staff will gladly answer any exhaust questions that you may have.
  17. Apr 11, 2018 at 2:31 PM
    Gus 524
    Justin
    MN
    Sounds good, thanks for the info!
