Looking to replace all my vacuum hoses, looking for lengths I would need
Discussion in '1st Gen. Tacomas (1995-2004)' started by ps6000, Nov 11, 2016.
  1. Nov 11, 2016 at 11:19 AM
    ps6000
    ps6000 [OP] Active Member
    I have a 2000 6cyl prerunner. My hoses are in really bad shape, error code and some intermittent surging makes me think a vacuum hose might be at fault.
    Does anyone know the lengths and diameters I would need to replace all of the hoses?
  2. Nov 11, 2016 at 11:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have found it easier to just buy 50' rolls I would have to go luck at the sizes
    CD20H likes this.
  3. Nov 11, 2016 at 4:00 PM
    mrfish27
    mrfish27 MrFish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Air lockers, RTT, aluminum armor, lithium 2nd battery
    I went to the dealer and bought most of the hoses, except the few that are straight runs. They are reasonably priced and you can't beat the fit.
    The straight runs I took down to my local Napa for replacements. I was surprised that they don't offer all that many choices in vacuum lines.
    When I do it again, OEM all the way.
  4. Nov 11, 2016 at 8:26 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    suggest you just buy 10 feet of it and cut it all to size as you go. it's not expensive....
    Aussiek2000 likes this.
  5. Nov 11, 2016 at 8:43 PM
    MtRSQ
    MtRSQ I am that I am.
    Brandon
    Utah
    3rd Gen, White, 4Door, V6, TRD, 6MT.
    285 70 R17 BFG KO2's,17” Bronze SCS Billet Wheels, 2.5" Ebaich Lift, MagnaFloe Overland Catback Exhaust (turned down @ axle), Rear Axle Breather Mod,
    Need to do the same thing on mine... went by the dealer the other day and it would be close to 300 dollars to do it all oem.... so instead went with the platinum silicone hose kit off Amazon... by some rough calculations I should have enough with the 5 different metric sizes.... miuns the radiator...
  6. Nov 12, 2016 at 8:34 AM
    ps6000
    Mtrsq, I was looking at silicon but CA smog sometimes fails cars because of that. I guess I can get black and risk it. Do you know the diameters of the kit?
    Codeseven, do you know what diameter hoses I should buy? I am fine buying 10 feet of a bunch of hoses and just cutting it, but don't want to make a mistake on the wrong diameter hose causing an issue.
    Mrfish27, what did it cost you for oem? I didn't even look because oem always meant more money than I have.
  7. Nov 12, 2016 at 8:58 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    I need to do the same.
  8. Nov 12, 2016 at 9:19 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Just get rubber.
  9. Nov 12, 2016 at 10:13 AM
    ps6000
    Yes, but do you know the diameters required? I was trying to find something that lists the diameters so I could he'd to the store and pick some up. But I can't find that documentation.
  10. Nov 12, 2016 at 3:10 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Part 90999-92003 is 600mm of the standard small Toyota vacuum hose. The larger sizes of vacuum hose, like for brake booster, etc., I'm not sure of.
  11. Nov 12, 2016 at 7:14 PM
    CodeSeven
    Serge.
    Coachella Valley
    if you buy actual vacuum hose, you CAN'T get the diameters wrong. vacuum hose material is so strong it wont affect anything. so long as it pops onto the tits you need them to go on, your good.
    if you want to be sure. remove ALL of your vacuum lines and go tot he auto parts store and say, I need all this!
    or you can just pop off every hose and measure the IDs of them with a tape measurer and tally each of them up along with lengths. but that might be too easy, so i dunno :cheers:
    MtRSQ likes this.
  12. Nov 13, 2016 at 5:36 PM
    ps6000
    Thanks for all the help everyone. I went to autozone and just mixed and matched till I got what I needed. I was real worried that the wrong diameter would cause problems, guess I didn't think that as long as it fits I would be OK.
    MtRSQ likes this.
