Looking to spend some money
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gboy66, Jul 14, 2014.
  1. Jul 23, 2014 at 12:24 PM
    #121
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Soundproof it ....so no one can hear the screams :anonymous:
  2. Jul 23, 2014 at 12:38 PM
    #122
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Painting the headlight "bezel" to do the BHLM won't affect light output much at all since you leave everything else, ie, reflector bowl alone.
  3. Jul 23, 2014 at 12:49 PM
    #123
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I'm guessing the eco tires are whats helping you, I currently have rockstars and trail grapplers, they're probably the heaviest options available, each tire is 74lb and the rims are 35lb. Im going down to 265 dynapro atm's soon and I think that will help, theyre only 40lb, I may also reduce my lift to 1.75" instead of 2.5".
  4. Jul 23, 2014 at 1:01 PM
    #124
    Yota64
    Yota64 Professional Threadjacker
    I just looked up the bezel and the reflector bowl is self explanatory.
    In a BHLM, which one are you painting? I guess I have seen both.
    I thought you painted the reflector bowl black too. That's what I see a lot of retrofits do, which sounds like it would severely reduce light output
    Holy crap! That is a lot of weight!! You need a regear for that don't you?
    Yes the eco tires help with rolling resistance and the larger diameter helps travel further. They are not harder to turn because though there is more rubber, (couple lbs per tire more probably) there is also less rim weight (20 chrome to 16" alloy). The larger distance from endpoint to axle makes it harder to turn but it is negligible.
  5. Jul 23, 2014 at 1:17 PM
    #125
    JdevTac
    Josh
    MD/GA
    2nd gen
    You paint the bezel for the BHLM...and the reflector bowl is left completely alone unless you retrofit. If you painted the reflector bowl without retrofitting you'd have zero light lol. Seeing as retrofits use projectors which have their own built in reflector component so that's why you can paint the stock reflector bowl as it isn't used any more.
    EDIT: BHLM in the sense of BHLM is just painting the bezel which is the trim. A full on retrofit is the only reason you'd paint the reflector bowl to get that aggressive headlight look.
  6. Jul 23, 2014 at 1:20 PM
    #126
    Yota64
    Got it. So ALL A BHLM is is painting the bezel? No tinting the glass or anything?
  7. Jul 23, 2014 at 1:21 PM
    #127
    JdevTac
    Josh
    MD/GA
    2nd gen
    Correct. Bezel and nothing else.
  8. Jul 23, 2014 at 1:24 PM
    #128
    Yota64
    That sounds simple. Lot of gain from small cost/time. I will try this soon if my lenses will allow. So has anyone done any variations or are they all 100% the same?
  9. Jul 23, 2014 at 1:44 PM
    #129
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    My .02 worth.....don't rush any decisions. Sounds like you're doing your research..keep it up. I bought new wheels for my truck and ended up finding others I liked better like a week after I had my new ones installed.:frusty:
    I just bought blacked out DEPO headlights off Amazon for $99. Couldn't be happier. Same light output as stock plus look good. I sealed around the edges of the lights with silicone to prevent moisture issues like some have had. So far so good. I didn't want to go through the BHLM either and these work for me.
    http://www.amazon.com/gp/product/B00KAI6CFY/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    You get everything you need. I see that they are $119 now. Still a good deal IMO.
  10. Jul 23, 2014 at 1:51 PM
    #130
    Gboy66
    Gboy66 [OP] Well-Known Member
    Grant
    California
    06 prerunner sr5 sport
    Added a subwoofer
    That looks good. Did you do the install yourself?
  11. Jul 23, 2014 at 2:38 PM
    #131
    Yota64
    That is a good deal and they look good but I still would rather do the BHLM if possible.
  12. Jul 23, 2014 at 3:00 PM
    #132
    JdevTac
    Josh
    MD/GA
    2nd gen
    People have also color matched their bezels. Looks great on certain colors. I've seen speedway blue, red, white, and also MGM color matched. Just search up "-insert color here- headlight mod" and I'm sure you'll find other pics. Here are some I pulled up:
  13. Jul 23, 2014 at 4:12 PM
    #133
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Those are the same lights I suggested before, just a better price.
    Also no offense, but if you can't unbolt the stock headlights and swap them with replacements you should probably hold off on modifying your truck and do some research here on TW. Just my 2 cents
  14. Jul 23, 2014 at 4:51 PM
    #134
    Bagman
    Area 51
    Yes I installed them. First one took about 25 minutes, second about 15. Very easy to do. There are several YouTube videos out there that walk you through the process of removing and re-installing your lights.
  15. Jul 23, 2014 at 11:33 PM
    #135
    TacomaTruckParts
    TacomaTruckParts Well-Known Member
    Jesse
    San Gabriel
  16. Jul 24, 2014 at 6:31 AM
    #136
    Yota64
    Thanks for doing that. Those do look good! However, I meant if anyone had painted a different piece of the assembly. But I couldn't think of what else to paint.
    I have always seen flat/matte colors for HLMs. Has anyone done a glossy/anodized? How would it look?
    I don't think he meant he couldn't do them, but I agree, research, research, research, until you can perform the desired DIY.
    And though I don't think he meant that, it is indeed strange to imagine someone having headlights installed by a shop :rolleyes:
    I can't wait to do BHLM; finally, a cheap mod
  17. Jul 25, 2014 at 6:22 PM
    #137
    Gboy66
    Grant
    California
    Added a subwoofer
    Dads giving me a hard time saying "been driving around San Diego and i've seen taco's that are way cooler than yours"
    Ok...motivation= found
    Ordered the tailllight tints, 35% light grey
  18. Jul 25, 2014 at 6:26 PM
    #138
    Bagman
    Area 51
    That's a good start. Be sure and post up pics of the upgrade. :proposetoast:
  19. Jul 27, 2014 at 9:23 AM
    #139
    Gboy66
    Grant
    California
    Added a subwoofer
    Installed the roof racks yesterday...loving them!!!5aqazu7u_2dc3fc2086a1236083ebfe8d28baf4fda4f1ad56.jpg
  20. Jul 27, 2014 at 10:10 AM
    #140
    Pistol Pete
    Eric
    Oklahoma
