looking to upgrade from procomp lift
Discussion in 'Suspension' started by XPOTRPR, Jul 11, 2011.
  1. Jul 11, 2011 at 11:42 AM
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hey guys,
    I have a procomp lift on my truck and running 285 nittos. I bought the truck used with the lift already on it so I honestly dont know a lot about It. I do know it rides stiff and I have rubbing issues at full turn when backing up. I did some trimming but still have issues. I am looking to improve ride quality and have no plans to add armor or anything up front. My question is, what shock and coil combo would be best to add another half inch to the front and improve comfort. Im ordering new UCA's regardless. I'm just not sure which set up would be best. 5100s or OMEs for shocks, and either OME or Eibach for coils. OR go with the Icon extended coil over. Obviously that will be the more expensive route. Again, I'm just looking to add another half an inch to the front to bring nose up level/just a tad high, and improve ride quality. Any input is appreciated. I've read through the threads and understood some of it, but I'm still new to the suspension. I know 886s are for armor, so 885s? Or even lower? Help me out guys. Too much info for me. Lol
    Edit: what about OME 884s with the spacer plate and 5100s.. or without the spacer plate and 5100s set at the lowest setting?
  2. Jul 11, 2011 at 9:10 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    x2 lose the sway bar if its not already gone it makes a huge improvement both on road and off. i have the pro comp lift as well and i love it. its pretty solid man you could do alot worse for 3 inch lifts i guess.
    if i read your post correctly and your wanting to go higher you will need a drop bracket to keep your cv angles from self destructing and other goodies from imploding as well. pro comp fabtech and rcd make drop brackets but they are pricey and you have more ground clearance with the 3 inch and 33's then you do with a 6 inch and 35's.
  3. Jul 11, 2011 at 9:12 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    if your looking to stay at three inches ome makes a solid kit as well many many people run them and they are awesome you simply cannot go wrong with arb products they just work.
    although the same could be said for the pro comp lift.
  4. Jul 11, 2011 at 9:39 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks guys.. I was actually going to take my sway bar off this last weekend, but was worried with the pro comp lift, that I woukd blow out a shock and or have even more rubbing issues. The lift isnt bad, I just wanted like a half an Inch more maybe just to raise the nose. It's not a must, just figured it would look a little better. I was thinking of the OME kit, but there's so many different shocks and coils to choose from. It's overwhelming. Lol. I'll start with the sway bar removal and go from there I guess. Thanks again for the feed back.
