Looking to upgrade my speakers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdriii, Sep 12, 2023.
  1. Sep 12, 2023 at 8:01 AM
    jdriii
    jdriii [OP] Member
    Joey
    NC
    2010 Silver TRD Sport PreRunner AC
    I am wanting to upgrade my front door speakers because the stock ones just aren’t that good. I love music with tons of bass and the stocks don’t really do it for me. I have a little wiring experience but not very much. I just want something easy and cheap but something with good bass and sound. I’m also using the stock head unit, is that something I should look into replacing as well?
  2. Sep 12, 2023 at 8:20 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
  3. Sep 12, 2023 at 8:20 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
  4. Sep 12, 2023 at 8:35 AM
    TikiBird
    TikiBird Well-Known Member
    06' Tacoma ACLB TRD Pre-runner, Leer 122 shell.
    crutchfield.com, if you buy speakers from them they throw in the adapters and mounting ring for free
    it's super easy, you can do it in less than an hour
    Geeves77 likes this.
  5. Sep 12, 2023 at 8:48 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Yup get the adapters
  6. Sep 13, 2023 at 2:58 PM
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    You need an amp if you want bass. Then....it all begins from there and snowballs :D
    photodoc and vtown like this.
  7. Sep 14, 2023 at 8:20 AM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    The stock head unit is low power, new speakers will be a mild improvement but if you want good sound you need to replace it all. Head unit, amp, speakers and a sub.
    photodoc likes this.
  8. Sep 14, 2023 at 8:28 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    No such thing as good and cheap. If you want more bass you want a sub...but then if you add a sub the speakers won't be loud enough so you will likely want speakers and and a speaker amp...car audio gets expensive really fast.
    vtown likes this.
  9. Sep 14, 2023 at 8:48 AM
    vtown
    CT
    Spot on. If you want decent bass you aren’t going to get it without a sub.
    I will say that you can build a reasonable decent system in an AC without going too nuts, but it depends on you definition of too nuts.
    I did a pioneer touchscreen headunit ($600ish)
    Focal 4 channel amp ($250ish)
    Front door Polk 6” speaker component separates ($200 ish)
    Polk 8” sub ($100ish)
    Homemade sealed box
    Miscellaneous wiring ($100ish)
    Major upgrade over stock. I’m happy with it but it’s still l pretty basic.
    Im in for ~$1300 for a basic system and I did all the work including a custom box. Ask yourself if that is a price you can swallow.
    you can do something for a little less (there are cheaper headunits, but I wouldn’t go too cheap on the speakers or amp)
  10. Sep 14, 2023 at 8:54 AM
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    That's a pretty good intro setup that prob sounds great. I think OP can get away with skipping a head unit and doing LOC off stock. Doing it yourself is where you save a lot.
    vtown[QUOTED] likes this.
