Looking to upgrade
Discussion in 'Performance and Tuning' started by crazyscout, Jun 17, 2010.
  1. Jun 17, 2010 at 9:53 AM
    crazyscout
    crazyscout [OP] Member
    Texas
    02 PreRunner SR5
    I enjoy my little 4 banger 02 PreRunner SR5 Taco and it's good on trails and mild off-road, but sometimes I feel I need more power to get where I really want to go. A friend told me I should put a small block 350 in it but I'm skeptical about that. Any suggestions on what I should do?
  2. Jun 17, 2010 at 10:07 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    What mods have you done so far? Does this truck see a lot of highway use?
    Gears are always a good choice to get more of the engine power to the ground. The downside is you'll rev higher at highway speeds.
    A v8 swap is not a cheap option and you'd save money buying a new-to-you v6 Tacoma and selling yours.
    Do you have a budget?
  3. Jun 17, 2010 at 10:11 AM
    crazyscout
    Texas
    02 PreRunner SR5
    I haven't done anything to it yet and it sees a fair amount of highway use. I've got a buddy who is planning on hooking me up with a suspension lift, changing the gear ratio and maybe one or two other things. I'm just waiting on him to get back from Iraq. My budget isn't too high right now, but at the end of the year it will be nearly unlimited.
    I'm looking for things I can mostly do myself for reasonably cheap. If I don't have to swap the engine I don't want to. But modding the engine is a possibility
  4. Jun 17, 2010 at 10:28 AM
    mjp2
    NJ
    Cheapest and easiest option: search for "deckplate mod" :)
  5. Jun 17, 2010 at 10:30 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You won't see any real power gains unless you turbo or supercharge. Horsepower is expensive.
  6. Jun 17, 2010 at 12:32 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just wondering what situations you're getting in where more power is the answer? Most of the time off-roading is much more technique and driving skill then power. Properly geared that 4 banger should be just fine, unless you're climbing trees...
  7. Jun 17, 2010 at 2:11 PM
    crazyscout
    Texas
    02 PreRunner SR5
    I guess power isn't quite the right word. I was using it more as a general term. A lot of what I'd like to get into is steep slopes with heavy underbrush on exposed bedrock and whatnot. I threw my buddy's tires on and they were gripping but when I got any kind of forward movement I was stopped by a small rise or something of the sort. I also like to tear through the mud but I can't get into anything too soupy. I'm friends with a lot of mechanics and they were the ones suggesting the engine swap so I could just muscle through what their boggers do.
  8. Jun 17, 2010 at 7:18 PM
    crazyscout
    Texas
    02 PreRunner SR5
    Can anyone tell me how to change my gear ratio? I'm not incredibly mechanically inclined. Just know how to change my oil, spark plugs, filters etc. Never had to do anything more
  9. Jun 21, 2010 at 6:43 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Surprised no one has responded. Changing gears is definitely a more involved mod to do yourself. I've never done it personally, but have checked into it. Need 2 sets of gears, front and rear, 2 install kits (bearings, washers, etc.), plus the install. I think it was around $1500 last I checked, with someone to install it.
  10. Jun 21, 2010 at 6:56 AM
    mjp2
    NJ
    He's got a pre-runner so it's only 1 set of gears.
    Best option would be to remove the 3rd member, ship it to get regeared, and just reinstall when it's sent back to you. I think some places do it the other way around and will send you a complete 3rd (center section of the differential containing the ring and pinion gears) so you can install and then ship yours to them as a core return.
    With a drop-out 3rd member, the gear mesh can be set up someplace else and all you have to do is remove your existing stuff and bolt in the new piece. It requires removing your rear brakes and sliding the axles out of the axle tubes, but it's not too bad a job if you're handy and have the right tools.
