looking TRD wheels for my 2020
Discussion in '3rd Gen. Tacomas (2016-2023)' started by summiz, Sep 18, 2020.
  1. Sep 18, 2020 at 5:45 AM
    summiz
    summiz [OP] Member
    Rob
    2020 3.5 tacoma
    Hey all, moved to MA and I like Toyotas so I got a 2020 3.5 Tacoma. This is the first truck I've ever owned. Its got the steel wheels 245/75/r16 tires, and im not a fan. I found some 265/70/r17 TRD wheels. That's same overall diameter i believe, so no speedometer or TCS issues right? I also know ill need to have the TPMS sensors programmed. Any rubbing issues? Thanks for any assistance :)
  2. Sep 18, 2020 at 7:42 AM
    JaysTRDsport
    JaysTRDsport Well-Known Member
    AJ
    2020 Tacoma Trd sport 4x4 6spd manual
    Toyo off road tires
    You won’t have a problem since it’s stock suspension and the larger TRD wheels You want will have the right size tires so it will fit the same in the wheel wells so you have the same height on your truck but look better.
  3. Sep 18, 2020 at 7:49 AM
    summiz
    summiz [OP] Member
    Rob
    2020 3.5 tacoma
    Ok thanks!
