Looks like it's not a 7GR, EPC partially updated: 2GR-FKS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Jun 12, 2015.
  1. Jul 4, 2015 at 4:32 PM
    #461
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    You can't get a manual double cab with the long box in the states either. Hopefully toyota corrects this situation
  2. Jul 5, 2015 at 10:45 AM
    #462
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If thats really new engine, I would like to be first one to congratulate Toyota eng team on yet another fail...
    Putting oil cooler coolant lines at the bottom of the engine is the dumbest idea ever. They already rusting on 3UR engines and those are tacked more to the side.
    here you have them in front of engine as what ? Salt overspray catchers?
    Oh and BTW when they stick like that, they like to get punctured by various low flying objects.
    Oi vei - you would thing putting that crap on 3UR was dumb, making it worse is just flat out crazy.
    Kids don't do drugs.
  3. Jul 5, 2015 at 10:51 AM
    #463
    Old School
    Old School You are ignoring covfefe by this member.
    Sounds like you should apply for a job with Toyota, you seem to have such knowledge of their products, you'd be a real asset to their team!:laugh:
  4. Jul 5, 2015 at 2:07 PM
    #464
    BlueT
    NorthEast
    I am not in car designing business. Plus, I would not fit well in their team. I don't work well with Liberal Art grads with out common sense.
    It's not complicated, low lines get over spray, and they rust. All they should do is take couple of their trucks on the lift and check bythemselves. Why you think lower idler in 1gr is first one to die?
  5. Jul 5, 2015 at 2:13 PM
    #465
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Thinking Liberal Arts grads design engines :facepalm:
    If the lines are well protected by a skid plate it will be fine.
    Old School likes this.
  6. Jul 5, 2015 at 3:28 PM
    #466
    Old School
    :facepalm::laugh:
    :tinfoilhat:
  7. Jul 5, 2015 at 3:30 PM
    #467
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    That's the best critique you've got? You're reaching...
  8. Jul 5, 2015 at 4:51 PM
    #468
    BlueT
    NorthEast
    Yes that worked so well for frames. .....Are we doing the same thing again ...
    I posted this in Dec 2010
    Two years later Toyota included plastic covers for frame holes... with their truck..... It was too late for many, their frames in those locations look like swiss cheese.
    It was common sense, Toyota eng should have seen this when they designed frame in 2004.
    Same thing now...
    Give some time... Toyota will catch up...:rofl:
  9. Jul 5, 2015 at 4:53 PM
    #469
    Old School
  10. Jul 5, 2015 at 4:59 PM
    #470
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    BlueT thinks he is the one that got a vacation, when really it was us :p.
    In all seriousness I doubt the layout of the engine from those basic schematics has any significant flaws. Toyota has been building engines for a long time with no problems. BTW it was Dana that fudged up the frames, both on the first and second gens. The new 2016 frames have a different composition.
  11. Jul 5, 2015 at 5:08 PM
    #471
    BlueT
    NorthEast
    Meh so they build the frames, bunch of fanboys here claimed there is no problem with 2 gen frames, Toyota is now replacing all 2005-2008 frames.
    been there done that.
    Give some time... :D
  12. Jul 5, 2015 at 5:10 PM
    #472
    Tideline
    Tideline Well-Known Member
    Back to the topic
    Bring me up to speed please
    It is for certain the 7GR ?
  13. Jul 5, 2015 at 5:24 PM
    #473
    Herniator
    Edmonton
    Toyota has succesfully sued Dana corporation for those years of frames that BlueT is complaining about. Its common knowledge, at least for most people who are members here. They have addressed the issue and have made improvements on the 3rd gen frame. Regarding strength with the high strength steel and as a byproduct the high strength steel is also more rust proof. Also Toyota isn't the only manufacturer who has had rust problems on their frames.
    I trust Toyota just a bit more then I trust BlueT.
    nv529, 23Skidoo, StAndrew and 2 others like this.
  14. Jul 5, 2015 at 5:45 PM
    #474
    tubesock
    tubesock Well-Known Member
    The most important engineering decision to balance when designing an engine is rust mitigation. That's why so many blocks and heads out of aluminum now. Think about it. Those idiots at Toyota should have put the oil cooler on the exhaust manifold. There's plenty of room there, and the heat will evaporate any water immediately so it can't rust. It's the perfect solution. They ought to hire me to design their engines. Id also put the oil pan on the top of the engine so it can't get smashed on rocks.
    It's becoming more certain that it isn't the 7gr. For one, that engine code never got a suffix. Second, that 7GR is from a tentative document first released in April. And most importantly the parts catalog available to the dealers this week was just updated and shows the engine as the 2GR-FKS.
    I tried finding out what the FKS suffix means. F supposedly means its an economy DOHC, as opposed to performance tuned. K is a mystery, I read somewhere that it means maximum fuel economy. That seems consistent. And S seems like it used to mean swirl intake, but this is direct/port injected so that doesn't really make sense. Maybe they changed the meaning of S to be mode switching. Because the 8AR-FTS is a turbo, hence the T, and it's also an atkinson/otto and it ends in S.. yeah who cares.
  15. Jul 5, 2015 at 7:31 PM
    #475
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    The liberal arts majors are all teaching elementary school, not designing Toyota engines.
  16. Jul 6, 2015 at 5:24 AM
    #476
    BlueT
    NorthEast
    I dont know how Toyota sued Dana and Won too. Clearly it has to be something wrong with Toyota process not Dana proces. (its Toyota's powder painting process if you ask me)
    Here are links to 4runner frame rot. Look at the latest one, Toyota is about to open recall on 4th gen 4runners and those frames never were made by Dana because 4runner is made in Japan (top to bottom)
  17. Jul 6, 2015 at 6:25 AM
    #477
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Aren't a lot of those lines/fittings made out of aluminum? You know, that element on the periodic table that doesn't rust because it doesn't contain iron?
    Also, glad to see the timing CHAIN stuck around instead of having a belt. :D
  18. Jul 6, 2015 at 6:39 AM
    #478
    Tideline
    the2016 Tacoma V-6 is the topic
    can you go start a thread on 4 runner frame rust somewhere else ?
    Lord Helmet likes this.
  19. Jul 6, 2015 at 7:14 AM
    #479
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    I think the rust issues another reason of many that Toyota did not do a clean sheet redesign for the Tacoma. They can churn out frames now for recall AND the gen 3.
  20. Jul 6, 2015 at 7:18 AM
    #480
    Herniator
    Edmonton
    Are we going to start posting every vehicle that has rust issues? It will be a never ending conversation.
