Looks like it's not a 7GR, EPC partially updated: 2GR-FKS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Jun 12, 2015.
  1. Jul 6, 2015 at 5:26 PM
    #501
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    You don't need to be a mech engineer.... All the designers at Toyota are the liberal arts majors who couldn't cut it teaching elementary school
  2. Jul 6, 2015 at 5:29 PM
    #502
    Old School
    Old School You are ignoring covfefe by this member.
    Sure, and Blue T is an English major!:laugh:
    CaptAmerica and Lord Helmet like this.
  3. Jul 6, 2015 at 5:31 PM
    #503
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    :rofl:
  4. Jul 6, 2015 at 6:30 PM
    #504
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    No, the 1GR only has four main bearings. You have a bearing at each end and one between each of the two paired "V" cylinders (hard to explain). All V6's will have 4 main bearings and all I4's and V8's will have five. Number of bearings isn't really relevant, its the quality that matters.
    Count the bearing caps on the 1GR: 16 main bearing cap bolts on the top (4 per cap) + 8 main bearing bolts on the side (2 per cap) = 24 main bearing bolts for 6 bolts per main bearing.
    :thumbsup:
  5. Jul 7, 2015 at 9:02 AM
    #505
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    K isn't used on too many engine codes, in fact it seems to be something new, first used on the 1NR-FKE and 2NR-FKE late last year, both of which are Atkinson-Cycle engines with VVT-iE. It seems to be Toyota's new code for switchable Atkinson cycle (used in several other engines like the Gen-II 2UR-GSE, etc.).
    S used to be for swirl intake, but was only used for that back in the 70's/80's. More recently (as of 1998) it has been used for D-4/D-4S direct injection. (1AZ-FSE, 1JZ-FSE, etc.).
    Interestingly, Toyota seems to have stopped using "E" for EFI on many of their new engines (8AR-FTS, 2GR-FKS, etc.).
    The new engine uses 4 main bearings, just like the 1GR, just like every other Toyota GR engine (and all other Toyota V6's). In a V-type engine you almost always sacrifice the number of main bearings. An inline 6 will typically (but not always) have 7 main bearings instead of just 4 on a V-type. It's just a product of the design.
    The bearing design of the 2015 and 2016 Tacoma is basically the same. The main differences you can see in those diagrams is mainly where the oil filter is (similar to the Dual VVT-i 1GR-FE on the bottom front), where the oil cooler lines are, and that they've added piston oil squirters. Beyond that not much to see there.
    Jeff
  6. Jul 7, 2015 at 9:24 AM
    #506
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Jesus H. Tapdancing Christ, it's a damn graduate-level Toyota engine lecture in here. How many credits is this class, prof? De we all at least get credit for auditing it?
    I mean...damn. This is like, well, work.
    Jester243 and Old School like this.
  7. Jul 7, 2015 at 9:25 AM
    #507
    Z50king
    Eric
    Southern California
    Stock and loving it
    I'm taking it Credit / No Credit
  8. Jul 7, 2015 at 9:26 AM
    #508
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Main bearings go between the rod bearings. An I6 will always have 7 main bearings.
  9. Jul 7, 2015 at 9:28 AM
    #509
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    I-6 is the superior and ultimate engine setup, I think we all know that.
    monkeyface and StAndrew like this.
  10. Jul 7, 2015 at 9:29 AM
    #510
    CaptAmerica
    Cap
    Last inline 6 I drove was an M-935. I don't think that's comparable.
  11. Jul 7, 2015 at 9:34 AM
    #511
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Except it can't fit in the engine bay in most modern RWD applications. V8's actually occupy the room better because they are shorter and are also perfectly balanced just like an I6. V8's have smoother power delivery as well. All of those reasons are why the I6 is gone except for in very limited high performance applications.
  12. Jul 7, 2015 at 9:36 AM
    #512
    Z50king
    Eric
    Southern California
    Stock and loving it
    Sideways 4 is superior to all
  13. Jul 7, 2015 at 9:37 AM
    #513
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    Looking at the diagram I am almost willing to bet that they are going to a cartridge type oil filter like the current Tundras and 2GR.
  14. Jul 7, 2015 at 9:39 AM
    #514
    Z50king
    Eric
    Southern California
    Stock and loving it
    Does the cartridge go on the top or the bottom?
  15. Jul 7, 2015 at 9:41 AM
    #515
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Exactly.
    An inline 6 is as long (or longer) than a V12; think about it. While I LOVE the inline 6 and it's inherent balanced properties, it's just not a good engine design geometrically. Especially for a car that you'd want to turn well. A V8 is essentially two inline 4 cylinder engines mated at the crank. This means you get double the displacement AND a lower center of gravity. :D
  16. Jul 7, 2015 at 9:44 AM
    #516
    CaptAmerica
    Cap
    But it's fantastic in ginormous diesels. The M-935 could pull God down off his mountain if we could only keep the tires from spinning...
  17. Jul 7, 2015 at 9:45 AM
    #517
    taco206
    Mill Creek, WA
    Toyota Previa engine? I agree!
    I think the American 'nuthin beats a V8!" attitude has alot to do with it. But I likes me my I-6's. I bet the M3 guys like theirs too.
  18. Jul 7, 2015 at 9:45 AM
    #518
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    V4
  19. Jul 7, 2015 at 9:45 AM
    #519
    Jeff Lange
    Calgary, Canada
    Not always. It's not necessary to support the crankshaft between every connecting rod in all applications. Notable Toyota example: The Land Cruiser inline-6 (Toyota F, 2F, 3F and 3F-E engine) used 4 main bearings all the way until they discontinued it in 1992. It didn't get 7 main bearings until the 1FZ in 1993.
    Jeff
  20. Jul 7, 2015 at 9:50 AM
    #520
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    They learned real quick why this was a bad idea.
