Loose Antenna Mast (PSA)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtdog, Sep 21, 2019.
  1. Sep 21, 2019 at 1:18 PM
    vtdog
    vtdog [OP] Well-Known Member
    NH
    I was waxing (NuFinish) my '11 and saw that the antenna mast was loose in the screw fitting in the fender. 30 sec. fix to tighten with a wrench. I have never had that happen on any vehicle before.
    FYI to check yours
    TnShooter likes this.
  2. Sep 22, 2019 at 10:44 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Mine has done that several times. Last time I put some blue Loctite on it. Can't say yet how well that worked.
  3. Sep 22, 2019 at 10:46 AM
    WATaco
    WATaco Well-Known Member
    Ed
    Seattle-ish, WA
    '14 Tacoma ORD
    Leer, AllPro sliders, Prinsu, OME, JBA UCA
    same here, and it seems to be a Toyota thing. Sienna minivan seems hell bent on losing its antenna, seems I have to tighten a couple of times a year. I've not opted for the red loctite option yet, at this point it's just a habit when checking other fluids/filters.
  4. Sep 22, 2019 at 2:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I check mine frequently too.
    I’d go blue loctite. If you ever try to remove it with red, and it breaks off, it is real hard metal.
    Some people have had theirs break off and it’s a bear to get drilled out.
  5. Sep 22, 2019 at 8:58 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    yep. Loctited mine years ago
  6. Sep 22, 2019 at 9:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    maybe i should check this! :eek:
  7. Sep 22, 2019 at 9:11 PM
    medic2230
    Murph
    Bama! Roll Tide
    Yup, gets loose all the time. I just hand tighten it back and hit it again when I notice it.
