loose antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, Nov 3, 2010.
  1. Nov 3, 2010 at 12:25 AM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    My stock antenna keeps unscrewing on its own. I'll have to screw it in every other day or so.
    Is there any way I can fix this?
    Glue? Hot glue?
  2. Nov 3, 2010 at 12:27 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Teflon tape.
  3. Nov 3, 2010 at 12:32 AM
    Karo
    Karo
    La Crescenta, CA
    Grill
    U R A FUCKING GENIUS thanks!
  4. Nov 3, 2010 at 12:37 AM
    Matic
    Tricky Dick
    Easley, SC
    That's what they tell me. :)
    Go easy on the tape. 2 wraps is probably all you need.
  5. Nov 3, 2010 at 12:47 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Prob could use loctite.. green or maybe blue, NOT red.
  6. Nov 3, 2010 at 3:41 AM
    Dennis3553
    Dennis3553 Well-Known Member
    Dennis
    Buffalo Ny
    + loctite
  7. Nov 3, 2010 at 5:00 AM
    crazyman
    crazyman Not bothered....
    Crystal Beach, FL
    '11 4x4 DC/SB TRD/OR V6 Auto, Magnetic Gray
    Does Plasti-Dip count as a mod ?
    I just noticed mine had worked itself loose also.
    I'll try the blue loctite.
  8. Sep 17, 2011 at 6:51 PM
    Shortie
    Shortie New Member
    08 Tacoma SR5
    If you are looking for a permanent fix, J-B Weld works wonders.
  9. Sep 17, 2011 at 6:53 PM
    aidenhardcore
    aidenhardcore Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    Hey dude my 2010 does it all the time. I have to tighten it everyday lol. Sucks. I think toyota should fix it since all my friends are having the same problem. Boo.
  10. Sep 17, 2011 at 10:07 PM
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
    X2. Blue loctite works
  11. Sep 17, 2011 at 10:15 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    i put a little rubber O ring on mine .. worked wonders and still comes off easy
  12. Sep 18, 2011 at 1:35 AM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    Tighten it with some pliers. Don't just hand tighten it every time you walk by it.
  13. Sep 18, 2011 at 7:03 AM
    Tacoma Mike
    Southern Maine
    Don't use loctite.
    If you snap it off then it's a whole antenna assembly.
    just use the right size wrench and give her a little tug.
    Should not come loose.Then if you snap it off it is repairable.
    Hand tight will definitely get loose. Rubber "O" ring is an interesting idea
  14. Sep 18, 2011 at 10:43 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It needs to come off for the car wash, so use teflon tape and not loctite!
  15. Sep 18, 2011 at 10:51 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  16. Sep 18, 2011 at 5:19 PM
    Gregg
    Gregg Well-Known Member
    Gregg
    New Jersey
    2010 Access Cab TRD Sport 4x4 Magnetic Grey
    Mine used to come loose all the time. I just used a small adjustable wrench and a little pressure. Have not had a problem since. Over a year now. I'm sure teflon tape would work also. But I would still put a little pressure on it with a wrench.
  17. Sep 18, 2011 at 5:21 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    wouldn't you loose reception if you used teflon or loctite? i would just get a wrench on it and tighten it up.​
  18. Sep 19, 2011 at 5:48 AM
    Chris135
    Chris135 Well-Known Member
    Regina,Sk
    2011 Tacoma DCLB SR5 TRD Sport
    Debadged Bilstein 5100 shocks in front OME 885 coils Icon 1.5"aal 16" fj cruiser Trd rims 285/75/16 duratrac tires 1.25" spidertrax wheelspacers (4) Tinted front windows Grillecraft upper grille Custom Trd boxside decals Allpro front bumper Piaa 510 fog lights Box mounted ammo can Rear diff breather BHLM Tinted front windows Rolltop tonneau cover Hand controls (for wheelchair users)
    I wouldn't use loctite ad my experience is that over time bolts can become too tight and you risk stripping the head of the bolt or in this case the antenna. And as Tacoma mike said you will need a new assemble altogether which is just an unecessary cost/pain in the ass. I would also recommend the Teflon tape, just 1 or 2 wraps should be fine to make it fairly snug.
    And since it was brought up you should never take your vehicle through an automatic carwash that isn't touchless. The brushes and what not will scratch the paint. The touchless one suck too but at least they don't harm your vehicle.
  19. Sep 19, 2011 at 6:03 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    My wife's 04 Highlander and my 11 Taco both have issues.
  20. Sep 19, 2011 at 9:04 AM
    Cerberus
    Cerberus Member
    Massachusetts
    Tacoma 4x4 4.0L V6
    Don't add anything to the threads that's going to present an impedance discontinuity. You need a good, solid bond there.
    Try a metal lockwasher.
    Cerberus
