Loose axle going into T-case
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dave435, Nov 20, 2016.
  1. Nov 20, 2016 at 5:57 PM
    dave435
    dave435 [OP] New Member
    Dave
    2008 tacoma 4wd
    none
    I have a 2008 Tacoma and am hearing a humming noise around 55 MPH. The drivers side drive shaft has movement at the T-case. The passenger side drive shaft is solid going into the T-case. Need help..
  2. Nov 20, 2016 at 6:05 PM
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    Are you talking about the CVs going into the Diff? My driver side has play my passenger does not. Front what I've read that is normal.
  3. Nov 20, 2016 at 6:24 PM
    mt1961
    mt1961 Well-Known Member
    Kingsport, TN
    2015 TRD Sport
    Sounds like the needle bearing in the front differential. Get the ECGS bushing and it should solve your problem. Changed it on my '06 and was one of the first things I did on my 2015.
  4. Nov 20, 2016 at 6:39 PM
    1largemouth
    1largemouth Well-Known Member
    Martinez CA
    06 Tacoma
    Yup, ecgs is the way to go! Had the same issue
