Loose carpet lining on ceiling of cap
Discussion in 'Tonneau Covers, Caps and Shells' started by Area51Runner, Oct 1, 2016.
  1. Oct 1, 2016 at 1:12 AM
    Area51Runner
    Area51Runner [OP] Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Any suggestions on dealing with a couple of loose spots (as in sagging) with the oem carpet lining? I was thinking spray adhesive but the products I looked at today only didn't have a tip to affix a tube (think WD40 can) to.
    Thanks for any input
  2. Oct 1, 2016 at 5:10 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Swap spray nozzles for one that will take a straw/tube, poke a small hole in the carpet, stick straw in hole and follow directions on can. The adhesive will be thicker than a lubricant so look for something with a larger bore straw that wont clog as quickly. Also DAP makes some various adhesive that come with a straw or you could get a tube of adhesive that comes with the plastic pointy nozzle. You could get a syringe and put glue in it too but it'll take longer to dry. Plenty of options, just get creative.
  3. Oct 1, 2016 at 9:27 AM
    Area51Runner
    Figured others have run into this - thx for the tips I'll post what I come up with. Its not that bad but short of scraping the whole liner out and starting with a new one, i'm sure there is some way to repair the spots that are loose.
