Loose clutch fork
Discussion in '1st Gen. Tacomas (1995-2004)' started by MasterYota1992, Feb 10, 2022.
  1. Feb 12, 2022 at 6:37 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    IIRC the OEM one has 2 hole sets and you're supposed to use the ones with arrows next to it or something, your aftermarket may not have them as long as it aligns with the dowels and all dowels are installed it should be centered and good.
    Just make sure you run all the bolts in slowly a turn at a time in a star pattern to bring it down evenly.
  2. Feb 12, 2022 at 8:24 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Not exactly sure how the pivot broke in the first place. Looks like a case of "I need to get to work tomorrow" with the diy pivot though. I'm expecting you're replacing the pivot and fork with OEM parts. Check out McGeorge Toyota Online.
  3. Feb 17, 2022 at 7:08 AM
    MasterYota1992
    MasterYota1992 [OP] Member
    Ozzy
    OR
    2002 Tacoma SR5
    I did my best to tighten then evenly. I did the sequence n everything too. 14 ft lbs with a torque wrench to finish off. Did I do it properly? We will find out this weekend:oops:
  4. Feb 17, 2022 at 7:10 AM
    MasterYota1992
    Ozzy
    OR
    2002 Tacoma SR5
    Yes, I got all brand new clutch fork and pivot ball. I have all my parts now except for the shifter bushings I ordered from marlin crawler. Gonna try n wrap it up this weekend. Wish me luck...
  5. Sep 16, 2022 at 9:18 AM
    5efvz
    5efvz Well-Known Member
    Bump. How did it go?
  6. Sep 16, 2022 at 9:48 AM
    choopes
    choopes Well-Known Member
    Troy, Al.
    2004 reg cab
    Stock
    You are most unusual. You have owned and operated all 3 engine set ups. Which did you like best and for what reasons?
    Welcome to the forum.
