Loose E-Brake when Released
Discussion in '1st Gen. Tacomas (1995-2004)' started by genuine, Jul 8, 2010.
  1. Jul 8, 2010 at 7:14 PM
    genuine
    genuine [OP] Active Member
    Calgary, Alberta, Canada
    Bilstein 5100, AAL, Deckplate Mod, Magnaflow Cat-Back
    Hey,
    I have a loose ebrake on my 2003 tacoma. When I release the brake and put it in; the brake light stays on. If I push it in and hold it the light goes off; but otherwise it wiggles back and the light goes on....
    Any ideas what I could do / what I need to do to fix it?
  2. Jul 8, 2010 at 10:44 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I'm guessing the cables are rusted?? Not sure but that's where I'd start. Or maybe the spring that releases it. Mine gets stuck sometimes in the snow but it'll release once I've driven about a quarter mile.
  3. Jul 8, 2010 at 11:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    First off...you need to inspect your rear brakes.
    Check the condition of the shoes, and are they wearing evenly?
    Check the condition of the ebrake mechanism inside the drum as well as all the cables that attach to the drum and run along your axle tube.
    The cable could be 'stuck' due to rust & dirt.
    If everything checks out OK....then you can adjust the cable tension.
    http://www.lieblweb.com/ebrakeadjustment.html
    However, just an FYI..... If you ever change your shoes (rear brakes), you will need to readjust this again with new shoes on.
  4. Jul 9, 2010 at 6:46 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I had the same problem and all I had to do was replace a spring the pulls the cable from the cab tight. The spring is under the cab by the way. Just follow the cable till you find the spring under the cab. The spring cost me around $8 at toyota.
  5. Jul 9, 2010 at 6:57 AM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    my buddy and i both lifted ours and disconnected our ebrake, and our lights both come on nature of the beast
  6. Jul 9, 2010 at 7:12 AM
    Boosted17
    Boosted17 Well-Known Member
    Cliff
    Florence, Ky
    Looking for a new Toyota Truck.
    2006 Corvette Z51 M6. Best mod ever!
    Same thing happened with mine. Simple fix!
  7. Jul 9, 2010 at 9:13 AM
    genuine
    awesome!
    Thanks for your help guys
    Joey
