Loose Front Drive Shaft/Vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MRBIG77, Apr 24, 2011.
  1. Apr 24, 2011 at 7:26 AM
    MRBIG77
    MRBIG77 [OP] Member
    Utah
    07 Double Cab TRD Sport
    I've noticed a slight vibration that comes and goes in the front end of my 07 Tacoma TRD Sport. It will go away when I engage 4H. I've gone through the whole tire and wheel balance issue and actually found out I had a couple damaged rims. I climbed under my truck and noticed that the driver side front drive shaft has a lot of play in it when I grab it with my hand. The passenger side has little to no play so I'm thinking my vibration is related to the loose driver side shaft. Any thoughts? Could the damage extend into the front differential?:confused:
  2. Apr 24, 2011 at 7:27 AM
    MRBIG77
    MRBIG77 [OP] Member
    Utah
    I should also mention that I'm grabbing the front shaft at the point it enters the front differential.
  3. Jun 19, 2011 at 6:48 PM
    Toy2Dy4
    Toy2Dy4 Member
    Maine
    2011 Black SR5 Tacoma 4x4 4dr
    My 2011 dcab has had alot more play on the drivers side then the other side since it was brand new.. only has 3500 miles on it right now.. going to ask the dealer next time..
  4. Jun 19, 2011 at 7:02 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    Many have that vibe, especially when lifted. Maybe even all lifted 4WD's have the problem, as some people don't notice it. I have yet to drive a lifted 4WD without the vibe ...
    There are many, many posts on it as well, the infamous "goes away when switching to 4WD vibe". I have this problem for 35K miles and 3 years now, and it appears to not be getting worse.
  5. Jun 19, 2011 at 7:54 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
