Loose front quarter panel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Featherfreak, Mar 11, 2019.
  1. Mar 11, 2019 at 7:35 AM
    Featherfreak
    Featherfreak [OP] Active Member
    2016 Tacoma TRD
    It seems like my right front quarter panel is loose. I thought it was something with my suspension but when I grab the truck at the wheel well and rock it around it sounds like the quarter panel is loose.
    Any ideas on how to tighten this thing down?
    Thanks
  2. Mar 11, 2019 at 7:47 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Not sure how that could be. Have you looked under the hood at the bolts? Hows the alignment of the panel. If you are hearing noises from the front right, check the passenger side cab mount.
    G.
  3. Mar 11, 2019 at 7:55 AM
    Featherfreak
    2016 Tacoma TRD
    The alignment of the panel looks fine. When I’m driving the noise sounds like it’s just right and under the glove box but it’s coming from outside the cab.
  4. Mar 11, 2019 at 2:03 PM
    Featherfreak
    2016 Tacoma TRD
    After further inspection I think you moight be right. I think it might be the bushings on those cab mounts.
    Thanks
  5. Mar 11, 2019 at 2:11 PM
    Garyji
    Gary
    That's what it was on mine. Dealer fixed it in 30 minutes. Mine sounded like a suspension clunk/clank.
    G.
