Loose intake bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EarlHickey, Dec 1, 2022.
  1. Dec 1, 2022 at 6:24 AM
    EarlHickey
    EarlHickey [OP] Active Member
    2006 TRD Off-Road
    Hello,
    I need to change my vehicle info, but this truck is a 2022 with V6.
    Over Thanksgiving I noticed one of the bolts holding the upper intake manifold (also called a surge tank?) to the lower intake manifold was almost completely backed out of its hole. Since we were traveling I spun it back in and snugged it. Several of the other upper intake bolts were very loose. I snugged them all lightly but a torque wrench that goes down to 15 ftlbs wasn’t available. Truck has 5,000 miles on it. I plan to ask the dealer about it when I take it for service.
    Questions:
    Has anyone else had this happen? What was the final outcome? Anything beyond just tightening?
    Did I screw myself over by tightening the bolts so that the dealership won’t see a problem? I’d rather have not touched it, but it was a holiday weekend and there wasn’t a way to get it into the shop prior to needing the truck for a long trip.
    Thanks!
  2. Dec 1, 2022 at 6:42 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Lemon Law it.
    jk you're fine.
  3. Dec 1, 2022 at 7:35 AM
    eurowner
    eurowner Duke Sky
    Scoty
    You found the rattle on startup!
  4. Dec 1, 2022 at 5:14 PM
    EarlHickey
    2006 TRD Off-Road
    Wait, it’s supposed to rattle? Maybe I should loosen a few somewhere…..
    eurowner[QUOTED] likes this.
  5. Dec 1, 2022 at 5:15 PM
    EarlHickey
    2006 TRD Off-Road
    It’s red like yours. Not ready to lemon it….
