Loose MAF Sensor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cryptolime, Jan 5, 2023.
  1. Jan 5, 2023 at 10:50 AM
    cryptolime
    cryptolime [OP] Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    My truck has been shifting extra crappy lately and I noticed one of the screws holding the MAF in place was loose and it was rattling around a bit. Could this be causing issues? i plan on removing it and cleaning it anyway as soon as i get some MAF cleaner. 17k miles on the odometer.
    HondaGM likes this.
  2. Jan 5, 2023 at 10:54 AM
    Tacospike
    Two Trucks
    I don't think it could be the issue?
    Any noticeable difference revving it at idle in park /neutral?
    HondaGM likes this.
  3. Jan 5, 2023 at 10:55 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    It could cause unmetered air to get past the sensor and make the engine run oddly and MAYBE cause the trans to shift weird. If that is the issue, it should go back to normal once you tighten the maf back down.
    HondaGM and Tacospike like this.
  4. Jan 5, 2023 at 10:55 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    revs seem to hang for a split second and there is a vibration around 1300-1500 rpm after revving it up in park/neutral
    HondaGM and Tacospike[QUOTED] like this.
  5. Jan 5, 2023 at 11:00 AM
    fourfourone
    If it really is the MAF causing that, which it could, it should go right back to normal after you tighten it back down.
  6. Jan 5, 2023 at 11:03 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    If its loose/leaking it could be running lean....tighten it up and try it:playball:
    TnShooter and cryptolime[OP] like this.
  7. Jan 5, 2023 at 11:03 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    If thats the case it should kick a P0171 'too lean' code Id think?
    HondaGM and TnShooter like this.
  8. Jan 5, 2023 at 11:07 AM
    fourfourone
    I would think he would get that code or something similar by now especially if he's been driving it like that for a while.
    HondaGM and SR-71A[QUOTED] like this.
  9. Jan 5, 2023 at 11:31 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    17K and a 21. Take it in.
    HondaGM likes this.
  10. Jan 5, 2023 at 11:37 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    no codes at all. might not be leaking enough yet.
    HondaGM likes this.
  11. Jan 5, 2023 at 11:37 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    to tighten a screw? the dealer will probably say "cannot replicate issue" anyway.
    HondaGM likes this.
  12. Jan 5, 2023 at 11:39 AM
    fourfourone
    Did the truck act the same after you snugged up the screw?
    HondaGM likes this.
  13. Jan 5, 2023 at 11:50 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I haven't remove the MAF on the Tacoma but all the MAF's I have changed have an o-ring sealing the sensor in the tube. There should be no leakage unless the o-ring has failed. Also the screw hole is usually a blind hole, so there shouldn't be leakage there either.
    Also, if it was running rough and had an unmetered air leak, it would throw a code. Either a lean code or an MAF error code.
    HondaGM, SR-71A and Chew like this.
  14. Jan 5, 2023 at 11:50 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Possibly, depends on how much it was leaking. There is a threshold before a code will be set. A quick look at the LTFT would give you an idea.
    I doubt that is what is causing the shift issues. But you never know.
    HondaGM likes this.
  15. Jan 5, 2023 at 11:53 AM
    na8rboy
    WI
    You mentioned shifting funky. You paid for warranty. Plus MAF shouldn't come loose, and need cleaning at 17k.
  16. Jan 5, 2023 at 11:56 AM
    TnShooter
    Deogee
    STOCK
    I agree. It’s always better to let the dealership fix a problem under warranty.
    Accidents happen, if an accident happens while YOU are fixing it. Well, good luck getting what you broke fixed.
    After warranty expires, I’ll throw wrenches at it all day. :thumbsup:
    HondaGM and na8rboy[QUOTED] like this.
  17. Jan 5, 2023 at 3:09 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i'll let you know after work. haven't driven it yet.
  18. Jan 5, 2023 at 7:12 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    it's not running any worse. it's still running in open loop a lot when i let off the throttle so I think it still has some learning to do. I need to do some highway driving and complete a few drive cycles before I know for sure. going to clean the MAF tomorrow too. also getting my bidirectional scan tool tomorrow (Anyscan A30M) so that should be fun to play with. Maybe i'll just reset all the learned values for transmission/fuel trims/throttle.
  19. Jan 6, 2023 at 5:11 AM
    SR-71A
    Zack
    Southern Maine
    What is the truck relearning? Did you unhook the battery while checking the MAF?
    If you have a scan tool and are monitoring data, Id think mass air flow rate and fuel trims would be good ones to look at. Obviously a leak would lead to lower MAF rates and higher fuel trims, though Im still not convinced thats your issue.
    Speedfreak likes this.
  20. Jan 6, 2023 at 5:31 AM
    fourfourone
    I agree. To me if the maf was the issue he would notice a big difference after tightening it up.
