Loose Oil Filter - BLOWN Engine!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaGirlColorado, Dec 9, 2023.
  1. Dec 9, 2023 at 3:06 PM
    #41
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    These vehicles (and all, as I recall) have a key-slot to unlock the steering even if dead. And bed-tow-trucks have a winch. No need to start again after fearing significant oil loss.
    OP did not mention skid plate and did not mention oil where the oil filter housing supposedly grounded/was-pinned.
    That is before the dealer ever had it.
  2. Dec 9, 2023 at 3:31 PM
    #42
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    If it was one of those chain Oil Change shops, like Quikie Lube, etc., they always put a sticker in the windshield telling you to come back in 3000 miles or 3 months, whichever comes first. Her oil change was 4 months ago... so they will tell her to pound sand.
  3. Dec 9, 2023 at 4:00 PM
    #43
    pastoreater
    pastoreater doesn't know
    M
    5g 4runner
    It was a bout of sarcasm
  4. Dec 9, 2023 at 4:08 PM
    #44
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Nowadays it's 5K or 6 months but I see your thought process
    shakerhood likes this.
  5. Dec 9, 2023 at 6:03 PM
    #45
    not a charger
    not a charger Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    Insurance doesn't cover this.
    Kwikvette likes this.
  6. Dec 9, 2023 at 7:41 PM
    #46
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    She stated something about a “minor incident “ that she had a to get towed out of a day earlier. Actual footage.
  7. Dec 9, 2023 at 9:48 PM
    #47
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    how typical SUV drivers enter their driveway
    Rusty66[QUOTED] and joba27n like this.
  8. Dec 10, 2023 at 1:54 AM
    #48
    TacoTuesday1
    FL
    isn't it covered by a skid plate
    I also have legs
    used them to push my truck when battery died
  9. Dec 10, 2023 at 5:25 AM
    #49
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i can't imagine the oil filter canister coming loose. i torque mine to spec and it is always snug to get off. if i ever let anyone else change the oil in this truck, i would be inspecting it right after, checking the oil level, and checking it again the following day or two.
    as most know, changing the oil is not difficult but with the gasket for the drain plug and two 0-rings and torque specs for the canister, you really need to be paying attention and preferably sober.
    as far as damaging it, i do not see how that is even possible unless the skid plate were removed.
    this is a cluster and based on what has been posted, i do not see a favorable outcome for the OP.
  10. Dec 10, 2023 at 5:43 AM
    #50
    TacoTuesday1
    FL
    there’s nothing to imagine
    Truck is dropped off
    Explained to SA
    writes description in RO
    Read by tech
    Examined by tech
    Pictures taken
    says it was taken elsewhere prior
    Usually means double gasketing filter
    Drain plug loose
    Peel off not removed from filter
    Filter left loose
  11. Dec 10, 2023 at 5:49 AM
    #51
    545
    545 Well-Known Member
    2015 Access Cab
    This is the same as the last blown engine.
    Go get a meeting with someone as high up as possible at the dealer, and tell them to prove it. They can’t.
    Then tell them to fix it. Keep going until someone fixes it or they prove it was negligence that caused it
  12. Dec 10, 2023 at 5:50 AM
    #52
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Owners shouldn't have to check the work done on their vehicles after taking it to a shop.
    After my first experience, that became a habit I started doing.
    OP, sorry to hear about your predicament.
    Chew likes this.
  13. Dec 10, 2023 at 6:11 AM
    #53
    22Coma6MT
    certainly a possibility
    but 4 months passed
    not likely.
    never seen a filter
    for these trucks
    with a peel off
    whatever that is
    filter is installed
    in a canister
    can't be left loose
    maybe you mean
    the canister was left loose
    and not the filter
    i'd imagine so
  14. Dec 10, 2023 at 6:42 AM
    #54
    twtaco$
    twtaco$ Well-Known Member
    Maybe they don’t have the plate on?:notsure:
  15. Dec 10, 2023 at 7:18 AM
    #55
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    OP is 100% Sunday post and none of this prob happened.
  16. Dec 10, 2023 at 7:18 AM
    #56
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    Agreed ^^^ With the little information known it sounds like previous shop, or quick lube flavor of the day, may have completed a poor install and the wheeling and getting stuck may have put it over the edge. Sometimes poor craftsmanship takes a little while to show up. Either way I agree with others that if properly installed the filter should not come "loose/off". I took off the retaining clip first oil change 80 thousand miles ago. I have a well-earned distrust for dealerships, but in this case, I do not see how they could be at fault with the current information the OP has given.
    TnShooter[QUOTED] likes this.
  17. Dec 10, 2023 at 7:23 AM
    #57
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    If every one replied in poetry form, this place would be divine.
  18. Dec 10, 2023 at 7:31 AM
    #58
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    That would be great ha
    Sucks they blew their engine though
    Loving these replies
  19. Dec 10, 2023 at 7:35 AM
    #59
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    Pursuing Toyota for a definitive answer that it's not a warranty fix might be helpful in figuring out by who & how this was caused.
  20. Dec 10, 2023 at 8:39 AM
    #60
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    The lesson here: Do your own maintenance, then there's only one dumbshit touching your truck.
    I'd like to know more about the mud and gravel excursion that needed a pull. Did the truck get a wash and look-over for damage or just rode hard, put away wet?
    Chew likes this.
