Loose shift handle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pmo, Jan 23, 2012.
  1. Jan 23, 2012 at 8:26 AM
    pmo
    pmo [OP] Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    Anyone run into this problem?? 6 speed handle is loose on the shaft going into the top of the tranny. IT IS 2 pieces but has to be purchased as a unit! $375.00 cdn. We Thought the little bushing thing was worn. Seems the part the knob fastens is filled with a rubbery material and the lower has is inserted. Its not a problem to be concerned about just effing aggravating!
    If you have encountered this PM me with your fix if you were able to fix it.
    Thanks guys:):):)
