Loose shock -- Is this a sign that I need a refill?
Discussion in 'Suspension' started by bmoorefree, Jun 9, 2017.
  1. Jun 9, 2017 at 8:57 AM
    bmoorefree
    bmoorefree [OP] New Member
    Josh
    2006 Tacoma Quad Cab 4x4
    Hello all,
    I recently noticed a clunking noise coming from the from passenger side. I jacked up the truck and inspected everything and noticed that my shock is loose. I can easily rotate it with my hand.
    In my opinion, this is where the noise is coming from. It only occurs from a dead stop to about 5mph. If I accelerate really slowly, it does not happen. But, if I accelerate fast, it sounds like "click click click click" until I get to about 5 mph.
    I have Walker Evans with Remote reservoir installed on my 06 double cab.
    I made a short video showing how easy it is to rotate the shock with my hand.
    Is this a sign that I need a refill on the remote reservoir? or is there a bigger problem here?
    Thanks.
  2. Jun 9, 2017 at 10:02 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Your bearings need to be replaced. And due for a rebuild if you have that many miles on them.
  3. Jun 9, 2017 at 10:20 AM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    x2 those uniballs are shot. Super easy fix though. They are a little spendy but not too bad.
    Basically pull shocks off
    unbolt top hat.
    pull snap ring
    pop old uniball out.
    install new uniball with some anti seize.
    reinstall
    Bob's your uncle.
    I would do all 4 while you are at it.
    over and out
