loose side mirror?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RelentlessFab, Sep 30, 2010.
  1. Sep 30, 2010 at 11:59 PM
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Hey guys, just picked up a cherry '03 extended cab 4cyl 4x4, but on the 5hr drive back home the passenger side mirror (manual adjustment style) kept shifting out of position every 1/2hr to hour. Its pretty annoying having to constantly readjust it, so does anyone know of a fix for this problem, or should I just try to source a whole replacement mirror assembly from somewhere?:cool:
  2. Oct 1, 2010 at 7:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to the dark side of this 1st gen world... haha. Careful, it's a really slippery slope. :eek:
    Not sure what the answer is. Mine (electric, adjustable) have a little play in them. Probably from bashing into Western Hemlocks. :D But they don't get out of adjustment, just vibrate a little at high speed, in the wind.
  3. Oct 1, 2010 at 8:03 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Sounds like the cables inside the mirror have stretched out (maybe?). Do you adjust it with a stick from the inside? Or is it the type that you push the glass with your fingers? In either case unfortunately the only option is to replace the whole mirror:(. This is why manual mirrors suck.
  4. Oct 1, 2010 at 10:52 PM
    RelentlessFab
    Eric
    Still got my 07, this is the GF's rig and a test truck for some new 1st gen parts I'll be making. :)
    Damn. Yeah, they're the ones that you adjust with that little stick from the inside. Guess I'll have to look around for one off a totaled rig or something. :(
