Loose Spark Plug From The Factory
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redline870, Aug 10, 2020.
  1. Aug 10, 2020 at 1:33 PM
    Redline870
    Redline870 [OP] Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    My old boss was a die hard GM guy and was the same way. But you’d have to be pretty dumb to be a die hard GM guy anyways lol
    boston23, usmc2msu, DAS Taco and 3 others like this.
  2. Aug 10, 2020 at 1:33 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Same. I never break out the torque wrench either. Although I did cross thread one on a Silverado once when I was 16.
    shakerhood and CygnusX191 like this.
  3. Aug 10, 2020 at 1:34 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    only 1 firing correctly
    2 are burnt
    2 are MISfiring
    as I mentioned b4 i know NOT the respective cylinders they were removed from
    while they are laid out in a row...............may Not correspond with the cylinders they came out of
    was watching a race mechanic rebuild a 7second (F A S T ! )supra the other day
    he explained what was going on Inside the engine at teardown
    actually ' reading ' various components b4 failure
    those plugs as shown are Not in good shape................
    dont mind expanding on the matter
    tho i wont get into a pissin contest
    the photoz speak for themselves
    good luck
    AKGSD, DAS Taco and CygnusX191 like this.
  4. Aug 10, 2020 at 1:37 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
    With a $20 HF torque wrench, I embarrassed a guy who said that he wrenches on hydros and had a calibrated arm. Dood was struggling with warped rotors and I told him that torquing the lugs would fix him up. He didn't believe me but gave it a shot with my wrench. He might have been a bit red faced bringing the wrench back to me.
    They're too easy to use and have saved me thousands in breakage and frustration. The cheap digi torque adapters are even better for me.
  5. Aug 10, 2020 at 1:37 PM
    Redline870
    Yeah no way was I reusing them. That’s like reusing a condom. I’ll be interested to see the difference with the OVTune and properly torqued down. It already feels a lot better on the old gluteus maximus dyno
    DAS Taco, CygnusX191 and SandyTaco4x4 like this.
  6. Aug 10, 2020 at 1:37 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Nah, as long as you're not going full gorilla with a breaker you're probably in the neighborhood anyway. I was doing it for the curiosity to see if they actually tightened them at all. I don't torque me small engine plugs, life is too short.
    DAS Taco likes this.
  7. Aug 10, 2020 at 1:39 PM
    Redline870
    I use torque sticks on the lug nuts and then have a dedicated budget torque wrench for lug nuts. No way am I using my $500 digital Snap-On one for every lug nut I remove.
    CygnusX191 likes this.
  8. Aug 10, 2020 at 1:42 PM
    ROAD DOG
    FEW
    if i was out in the hinterlands
    needed to get moving to get home /back to civilization
    that mcgyver/ country boy / Boy Scout attitude can work
    most would avoid leaks .......loss .........breaks
    all the snap on & various goodies still might not get U home
    yet if one wants to avoid serious negative scenarios
    consistent procedures help
    me riding with U 1st person anecdotal is gospel
    hope we dont have to walk out
    Pibbles99 likes this.
  9. Aug 10, 2020 at 1:44 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. I'd never use an expensive wrench to break bolts free. I just know that torque tools have saved my bacon, esp on aluminum threads.
    eurowner, shakerhood and CygnusX191 like this.
  10. Aug 10, 2020 at 1:45 PM
    ROAD DOG
    FEW
    2 have ' Black ' deposits = Misfires
    2 are ' Burnt ' running excessively hot
    i ask which ONE (1) shows good health ???
    new plugs in after 10000miles id luv to see what they look like
    are U familiar with ' Indexing '
  11. Aug 10, 2020 at 1:48 PM
    Redline870
    ^^^ See, I knew someone would have something to say about it. It's a spark plug on a truck not a rocket ship. Even if I installed them 10ft/lbs higher, it's a huge improvement over the Toyota factory.
  12. Aug 10, 2020 at 2:10 PM
    Smacky2020
    Bristol, VA
    When shifting from P to R, R to D and vice versa, especially when cold, did yours clunk a bit? I was actually going to post a question on this but as a newbie was probably going to get a lot of "it's normal for a truck". Engaging Drive after reversing has a distinguishable clunk vs going from Park directly to Drive after being warmed up. Just curious if this is "normal truck thing" or something to look into like ATF fluid, diff fluid... etc. And yes, I was going to bring it up to the dealer at the 5k but wanted to confirm if/when they tell me "it's normal" speech.
    Edit: I should add i have absolutely no low atf symptoms like slipping, downshifting or good engagement. Monitored atf Temps and they stay below 200. I have not checked the level.
  13. Aug 10, 2020 at 2:19 PM
    Redline870
    Yes I was getting that clunk and it was a lot better after changing the fluids, remarkably better surprisingly. I went to the dealer to buy the fluid and they actually told me they don't use OEM toyota fluid, they said they use Mobil 1 out of a 55gal drum. You should buy the OEM fluid, the crush washers, and do it yourself. It's very easy and it's the only way you’ll be certain that you’re getting OEM fluid. Make sure you can get the fill plug out before draining it!
  14. Aug 10, 2020 at 2:35 PM
    Redline870
    I would also check the transmission fluid level, I flushed mine before replacing the spark plugs with a $20 oil transfer pump I got on ebay, it worked like a charm.
    - I put 11.2 quarts of water into a 5 gallon bucket and marked that level on the bucket so I knew when the full system amount had drained.
    - I disconnected the return line from the transmission cooler, put a hose on it and ran it into that 5 gallon bucket.
    - I put 14 quarts into a brand new 5 gallon container like this: https://www.uline.com/Product/Detai...VTtbACh2b4wH_EAQYASABEgKnGvD_BwE&gclsrc=aw.ds
    - I ran a hose from that container to the oil transfer pump and a hose from the other side of the transfer pump to the other side of the transmission cooler line that I previously disconnected.
    - I hooked the pump to my jump box for power. This is the pump I used: https://www.ebay.com/i/392618568949?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=392618568949&targetid=930621147540&device=c&mktype=pla&googleloc=9005173&poi=&campaignid=10459991409&mkgroupid=100467641501&rlsatarget=aud-622027676388%3Apla-930621147540&abcId=2146000&merchantid=6296724&gclid=EAIaIQobChMI2-X98smR6wIVBdvACh1OZAwHEAQYASABEgKifPD_BwE
    - I had a buddy start the truck and slowly run it through the gears while I ran the pump, putting new fluid into the tranny as it was emptying into the bucket.
    - Once the fluid level reached the mark, I let it run for a short while longer.
    - I then pumped the remaining 1-2 quarts into the fill plug on the side of the transmission.
    - I locked the transmission thermostat open with a 1/16 drill bit
    - I put the truck into "transmission fluid level check mode" and waited for the "D" indicator to come on.
    - As soon as it came on, I got under the truck and opened the plug for the level indicating tube (or whatever its called), the one that's removed with a hex drive allen head.
    - The excess fluid poured out and once it slowed to a trickle, I replaced the plug.
    - Verified the "D" indicator was still on indicating the fluid wasn't outside of the "temp level check range".
    If you only need to check yours, buy a couple quarts of ATF and do the last 6 steps I mentioned for the flush. The level check sounds like a pain in the ass, but if you're just checking it, it's not that hard.
  15. Aug 10, 2020 at 2:41 PM
    #35
    Redline870
    This is the transfer case fluid I used (if you don't spill any, you only need one). https://www.oempartsource.com/oem-p...MIgKiBq8iR6wIVD77ACh3LaQoiEAQYAiABEgLLUvD_BwE
    This is the differential fluid I used. https://www.oempartsource.com/oem-p...al-gear-oil-lt-gl-5-75w-85-1-liter-0888502506
  16. Aug 10, 2020 at 2:44 PM
    #36
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    I am in the same boat.
  17. Aug 10, 2020 at 5:04 PM
    #37
    Smacky2020
    Bristol, VA
    So what do you think ended up making the biggest difference: ATF, diff or transfer? I'm only just over 1k so not near servicing any of these. If anything, I would think it would be the ATF. If it's low on fluid, it's probably very close to what should be so thinking of just asking dealer to check the level (actually crack it open). Then again, I have absolutely no basis of comparison.
  18. Aug 10, 2020 at 7:01 PM
    #38
    Redline870
    The biggest difference was the transfer case and diff fluid by a long shot. I changed the diffs and t-case fluid at the same time, I don’t know which was causing the clunk. The ATF didn’t make a difference at all for gear selecting at a stop, it only made a slight improvement in the smoothness of down/up shifting.
    I’ve heard A LOT of reports of these trucks coming low on ATF from the factory. Mine was about 1-1.5 quarts low. I’ve also heard a few reports of low diff fluid from the factory. I would mention it to the dealer the next time you go in and sternly mention that you want the fluid levels visually checked for your transmission, differentials, and transfer case. For the price of these trucks, it’s the least they can do, especially considering their shitty QC track record. They can apparently check the transmission with Techstream, but it’s not that accurate, it’s more of a ball park measurement. Tip the technician $20 BEFORE he works on the truck and I can almost guarantee you that he will physically crack every plug open and check the fluid levels.
  19. Aug 10, 2020 at 7:05 PM
    #39
    Redline870
    You usually won’t see the technician so put $20 in an envelope with a note that says “take good care of her and lunch is on me”. I’m telling you, it works every time.
    AKGSD and CygnusX191 like this.
  20. Aug 10, 2020 at 8:18 PM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Finally! Some forum members with some common sense! Everyone here would torque spec their own nuts if they could.
    CygnusX191[QUOTED] likes this.
