Loose Spark Plug From The Factory
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redline870, Aug 10, 2020.
  1. Aug 12, 2020 at 2:41 PM
    #101
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Buy them from the usually auto parts store like everybody else. Where is this mythical place you buy from that never makes a mistake?
    Never said I could spot a tenth of a degree by eye, I clearly said that it is not difficult see a camber issue when the spec is negative and the wheel is clearing at positive camber. Did you even read my post?
    It doesn't take a skilled professional technician to correct the problem. It can be done with a couple I-beam's, fishing line, a tape measure, and a level. Let me guess, you use one of those fancy machines that you input the car, spin some laser gizmo, and it tells which way to turn the wrench?
    Don't get me wrong, I am not bashing you or trying to belittle your knowledge. Just trying to help you out.
    Redline870[OP] likes this.
  2. Aug 12, 2020 at 2:49 PM
    #102
    Redline870
    Redline870 [OP] Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    The bearing plates are only needed when you're making adjustments to allow the tires free movement during said adjustments, not to free the suspension from binding :rofl: If what you were saying was true, the suspension would be binding just driving down the road since were not always driving on bearing plates.
    The $50k Hunter alignment machine we had at my old shop had heads that clamped onto the tires and you simply rolled the car back and forth to give you the initial measurements. The locking pins never had to be removed from the bearing plates until adjustments were needed.
    mattleg likes this.
  3. Aug 12, 2020 at 3:00 PM
    #103
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
  4. Aug 12, 2020 at 3:01 PM
    #104
    Redline870
    @mattleg - I can't tell whether this has negative camber or not, can you? The bald inside edge of the tires isn't a dead give-away either. Do you know any "trained professionals" I could consult with?
    mattleg likes this.
  5. Aug 12, 2020 at 3:01 PM
    #105
    Redline870
    :rofl: :rofl: :rofl: You beat me to it! :rofl: :rofl: :rofl:
    mattleg[QUOTED] likes this.
  6. Aug 12, 2020 at 3:04 PM
    #106
    Redline870
    Oh man I can not stop laughing at that meme!
  7. Aug 12, 2020 at 3:41 PM
    #107
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    And it's only Wednesday. Wonder if he'll be back, I've got a few more meme idea's brewing.
    CygnusX191 likes this.
  8. Aug 12, 2020 at 4:11 PM
    #108
    Redline870
    He'll definitely be back, he can't help himself. Isn't it funny how he said he's been "turning wrenches for 30 years" yet has never received a used part and only rarely has to return something? Wrong parts were almost a daily occurrence at any one of the three shops I worked at. Then he starts throwing around terms like caster sweep thinking it will add some validity to his story. He's so full of shit, I guarantee you this dude is some grease ball tire shop manager. The only thing he's been doing for 30 years is conning people into buying shitty offbrand, high profit margin tires. I can only imagine the way he talks down to and belittles customers.
    TexasG likes this.
  9. Aug 13, 2020 at 5:14 AM
    #109
    Sungod
    Sungod Well-Known Member
    St Augustine
    I'm guessing you have never done an alignment or you are just not doing them correctly. I know guys that take measurements before they pull the pins, but they do that knowing they will get readings that show it out of spec. They pull the pins bounce the vehicle a few times and magically it is back in spec.
  10. Aug 13, 2020 at 5:38 AM
    #110
    Sungod
    St Augustine
    I buy from a number of source, but I also don't rely on the guy behind the parts counter to tell me what I need. I do the research myself and tell them what I need. Maybe that is why I don't have problems?
    I did read your post, and your assertion that you can eyeball 1 degrees of camber is with your eye still isn't possible. 15 degrees like the the picture you posted, sure, but that isn't what we are talking about and that isn't something that can be fixed with normal adjustments. We are talking about a typical everyday driver where the difference between in spec and out of spec can be fractional degrees.
    While it is possible to do an alignment without a machine, outside of a toe set doing anymore than that with real accuracy is extremely difficult. How are you sweeping for caster in your driveway? How are you measuring fractional degrees with your bubble level? You would still need a set of turn plates. I mean you could do anything and maybe get lucky and get it right, but if you are looking for precision and first time accuracy, you won't get that doing an alignment in your drive way.
  11. Aug 13, 2020 at 5:48 AM
    #111
    ConradTaco20
    ConradTaco20 Member
    Newfoundland, Canada
    2020 ACLB TRD OR MT
    My trade is ship design. Anything off a plumb line is very noticable. This is the case with hull form development as well as a front end picture of a vehicle with positive or negative camber. Not sure why he argues so much on these forums though lol.
    Vessels with 2 degrees of deadrise looks like a steep grade when you're used to looking at flat hull bottoms.
  12. Aug 13, 2020 at 6:20 AM
    #112
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    You called it, I owe you a beer.
  13. Aug 13, 2020 at 6:20 AM
    #113
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Oh I see, you're "that" guy. You spend all that time researching the the part you need, then criticize others who just walk in door, ask for the right part, and take a mere second to open the box to confirm. Not trying to stereotype you, but "That" guy, got it, thanks for clarifying.
    Never said I was doing it in my driveway. And no, not a bubble level. A proper digital camber level. Did you think I was building a house or something?
    TexasG and DES2009 like this.
  14. Aug 13, 2020 at 6:28 AM
    #114
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Too tired to look for it, but wasn't there a comment above about being able to tell an engine was running lean/had lost hp just by looking a picture?
    :popcorn:
    tonered likes this.
  15. Aug 13, 2020 at 7:00 AM
    #115
    Sungod
    St Augustine
    OK chief, I'll let you feel like you win and not respond to your next juvenile response. I wasn't trying to ridicule you for your ignorance, but apparently you have taken it that way. I can only hope that you have actually learned something the next time you jump into a subject that is way over your head. So when you get out in your driveway with your I-beam and fishing line and realize that you are way over your head because you find that your xray vision isn't as good as a precision laser that you can take your mess to a trained ASE certified professional to fix your mess. Just do us a favor and let us do our work and until you get the same level of knowledge that you listen a little more and talk a little less.
  16. Aug 13, 2020 at 7:29 AM
    #116
    Redline870
    I've done literally thousands of alignments. I could be like you and throw out terms like steering access inclination and scrub radius angle to try and add credibility to my story, but I don't need to since I actually know what I'm talking about. You on the other hand, do not know what you're talking about. Unless you're making adjustments or lifting the front or rear of the vehicle, then you don't need to pull the pins to get an accurate measurement. The case you've made is that a vehicle can't possibly be within spec unless it's on bearing plates... think about that for a minute.
    mattleg likes this.
  17. Aug 13, 2020 at 7:30 AM
    #117
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Oh good, I’m glad you realized your issues. If you hadn’t noticed all those responses were modified copy and pastes of your own posts; so really, you were arguing with your own juvenile self. I hope you actually learned something. Absolutely, next time I will come to you when I need:
  18. Aug 13, 2020 at 7:32 AM
    #118
    ConradTaco20
    ConradTaco20 Member
    2020 ACLB TRD OR MT
    @mattleg Do these come at the special price of "One Million Dollars"?
  19. Aug 13, 2020 at 7:48 AM
    #119
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I remember an entire shop full of ASE Certified techs "fixing" my LJ death wobble...
    Spoiler alert: "ASE Certified" doesnt mean shit
    TexasG and tonered like this.
  20. Aug 13, 2020 at 7:49 AM
    #120
    Rivermaniac
    Rivermaniac Well-Known Member
    Wtf does all of this have to do with loose sparkplugs ????
