Loose Steering at Speed After Rack Bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Diagram14, Apr 9, 2016.
  1. Apr 9, 2016 at 1:01 AM
    Diagram14
    Diagram14 [OP] Member
    UT
    04 DC Tacoma TRD
    I recently replaced my steering rack bushings as general maintenance. I took it out for a test drive and noticed that as I approached 50 mph a loose spot developed in the steering which increased to 2-3" of free rotation as I approached 80 mph. I had my regular shop perform an alignment but found the issue remained afterward. The bushing replacement is solid, the rack does not budge under steering load.
    I have seen vague mention, and no follow-up, of a progressive or variable power steering assist that may or may not increase steering firmness with increased vehicle speed. Is there any experience out there with this particular behavior and/or diagnostics.
    This problem occurred suddenly. I have been running my current suspension for 2 years with several alignments performed. I know the issue is not slip yoke or tie rod related because of its speed dependency and visual inspection.
    I appreciate any and all input.
  2. Apr 9, 2016 at 10:41 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have never heard of variable power steering assist in 1st gen Tacomas.
    Do you know the exact settings the shop got for your alignment? In particular, what is the caster setting that they achieved?
    More details on your truck would be helpful. Are you lifted? Is so, how much? Are you a 4x4 or a prerunner? What size tire?
  3. Apr 9, 2016 at 11:29 AM
    Diagram14
    UT
    04 DC Tacoma TRD
    Sure thing,
    Truck: 04 DC 4x4
    2.5" lift on mid-travel kit.
    Front: King C/Os, LR UCAs, new Toyota LBJs.
    Rear: Dakar w/ Fox
    Tires: Cooper Discoverer S/T Maxx 255/85R16
    As I am currently standing in a river fly fishing I do not have the alignment sheet on me but can say that all the metric windows were green suggesting that a factory alignment was achieved.
    Did I miss anything?
  4. Apr 9, 2016 at 1:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Two thoughts.
    As you lift the front end, the stock (green) caster range is inadequate. This is a by product of lifting an IFS suspension. One of the symptoms of low caster is a feeling of loose steering at highway speeds. Your LR UCAs are capable of being set so a higher caster number is possible. Check your alignment sheet to see what it says. For good driveability, I like my caster higher than +2.5 degrees. +3* or higher is even better if you can get it.
    The other thought I had on why all of a sudden. I suspect, it isn't. I suspect that your worn our steering rack bushings were masking the issue. Now that the steering rack is no longer moving around, you are now able to feel this other stuff much better.
  5. Apr 9, 2016 at 1:45 PM
    Diagram14
    UT
    04 DC Tacoma TRD
    I was thinking the same thing as I'm trying make sense of it. Some how the old blown bushings must have been dampening the slop.
    Do you have any technical reference material to explain the role of caster at highway speeds for lifted applications? I'm not doubting your advise, I'm a mechanical engineer and like to understand why.
  6. Apr 9, 2016 at 2:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I can't explain it in technical terms but as I understand it, 0* of caster is a veritcal line between the upper and lower ball joints. Positive caster is when the upper BJ is 'behind' the lower bj. In other words, its when that line between the two BJs is tilted back.
    But I know its waaaay more complicated than that. I am sure there are folks on here that can explain it technically on why it feels better. What I am sure of is how it feels and what adding caster does to that feel.
    FWIW, low caster will not cause unusual tire wear. Its all about driveability.
