Loose steering cause?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by the_black_tacoma, Apr 24, 2022.
  1. Apr 24, 2022 at 5:21 AM
    the_black_tacoma
    the_black_tacoma [OP] Well-Known Member
    Griffin
    IN
    2008 Black Tacoma SR5 AC
    A couple
    Hey all, been trying to pin down an issue for a while now and hoping somebody can give me some ideas.
    My steering doesn’t have much vibration at all, but it does have quite a bit of play and on rough ground the steering will jerk side to side when hitting bumps/potholes/etc. I can almost feel it rattle back and forth.
    Specs if needed:
    08 Tacoma 4wd
    3.5” lift Icon coilovers
    SPC ucas
    33x12.50s
    I suspect it’s the intermediate steering shaft, has anybody else had a similar issue? Wheel bearings were done a few months ago as were tie rod ends. CV axles are also fairly fresh. Thanks in advance.
  2. Apr 24, 2022 at 6:18 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    This sounds like it would be that upper steering shaft with that small U-joint in it, I would shoot some PB blaster in there and soak it down really really good for a couple days and hopefully it’ll loosen up for you
    the_black_tacoma[OP] likes this.
  3. Apr 24, 2022 at 6:35 AM
    Clearwater Bill
    Billy
    Largo Florida
  4. Apr 24, 2022 at 5:25 PM
    Frizzlefry
    Frizzlefry Member
    I'm dealing with this issue too. I've got serious play in the steering rack bushing. so maybe check that
  5. Apr 24, 2022 at 5:35 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Could be any number of things. Put the front end on jackstands and grab each tire. Push on it every which way and look for the source of play. Having someone behind the steering wheel can make it easier to detect where the play is.
    Places to suspect, in the order I would check them:
    - tie rod ends (inner and outer). even though they're fairly new, sometimes the aftermarket ones are shit and can go bad very quickly.
    - upper control arm uniball
    - lower control arm balljoint
    - upper control arm bushings (harder to check without unbolting the UCA from the spindle)
    - check torque on the mounting bolts for the wheel bearing to the spindle.
    - coil over's uniball where it mounts to the LCA (play in the suspension can contribute to feeling loose)
    - intermediate steering shaft
    - steering rack itself. if you determine that is where the play is it, you have the decision as to whether it is the mounting bushings or whether it is the teeth in the rack itself.
    If the truck has been wheeled, it's totally possible that it is the steering rack. Which sucks - because the aftermarket/rebuilt replacements aren't the greatest and the OEM units are expensive. Plus it's not a fun job to do.
  6. Apr 29, 2022 at 3:14 PM
    Frizzlefry
    Frizzlefry Member
    Let us know if you get this sorted out!
  7. May 16, 2022 at 7:04 AM
    the_black_tacoma
    Griffin
    IN
    A couple
    Going to try what post #3 suggests and see if that helps first
  8. May 16, 2022 at 11:23 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Had same problem and intermediate shaft was kind of sloppy so replaced . Still had some knocking jerking . Had checked tie rods in air and seamed good no play . Checked while on ground and had friend rock steering and felt inner tie rod loose .Replaced tie rods and rack bushing all good now :D
    So yea check what Mxpatriot sayed
