Loose suspension help please.
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikeNickolas, Feb 13, 2022.
  1. Feb 13, 2022 at 6:38 AM
    MikeNickolas
    MikeNickolas [OP] Well-Known Member
    Goodyear, Arizona
    98 Tacoma PreRunner 3.4
    Removed ashtray for weight reduction.
    My suspension feels loose as I'm driving down the highway and the front end shakes a smidge at 70 MPH. Replaced many parts but problem is still there. I probably look as if I'm drunk swaying around inside my lane.
    Here's what I have replaced so far;
    Upper control arms L/R
    Upper ball joints OEM L/R
    Lower ball joints OEM L/R
    Tie rod end links Moog L/R
    Rack and pinion
    Had alignment done, front tires started feathering on the outside tire, had another alignment done, rotated and balanced tires and the tires are "feathering" yet again.
    The front shocks were replaced roughly a few years back and I don't see any "wetness" on or around them.
    Any suggestions as to what to load next in my nice shiny parts cannon?
    Thanks!
  2. Feb 13, 2022 at 6:43 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Have you checked ower control arm bushings? Also, if you put in a reman rack and pinion check those bushings. I've bought a reman before with shot bushings.
    MikeNickolas[OP] likes this.
  3. Feb 13, 2022 at 6:49 AM
    Enigma8246
    Lee
    Central Arkansas
    Might also try another alignment shop. A good one should be able to tell you what is causing the issue. My shop won't do an alignment if there's anything out of spec because they know I'll want to fix it before spending money on an alignment. Some shops will charge for an alignment knowing it won't align properly.
  4. Feb 13, 2022 at 1:07 PM
    MikeNickolas
    Goodyear, Arizona
    Yup..... I went to Big O tires to get the alignment done. Seemed like I was bothering them for daring to ask for an alignment. They were the only shop around that would get me in the same day.
