Loose Valve Cover Bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyotamd, Aug 12, 2020.
  1. Apr 24, 2023 at 10:58 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I suspect the reason that they loosen up over time is because of the rubber in the washer and the VC gasket shrinking over time due to the heat cycle. They aren't necessarily backing out persay but when the rubber shrinks or weakens, there is actually less tension thus causing the bolt to be "loose". I wonder why Toyota went with this type of design for these washers because other Toyotas that I've owned in the past had purely metal washers.
    Area51Runner and 0xDEADBEEF like this.
  2. Apr 24, 2023 at 11:40 AM
    Jolly Onion
    Jolly Onion Cheap is not Good & Good is not Cheap
    Alex
    Forest Hills, N.Y
    2004 Tacoma 6cyl crewcab
    did think about using blue loctite but not in the threads, I am afraid that the bolts will break before the loctite gets loose. But you gave me an idea - if I do not find the studs. Maybe use just a little loctite under the bolt head between the valve cover and the bolt?
  3. Apr 24, 2023 at 11:42 AM
    Nessal
    Texas/Bay Area
    I wouldn't use blue loctite. Use purple if you have to.
    Jolly Onion[QUOTED] likes this.
  4. Apr 24, 2023 at 11:53 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Madjik_Man likes this.
  5. Apr 24, 2023 at 3:18 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    I think I am going to buy thin lock washers - just to put enough pressure for the bolts to stay tight.
  6. May 11, 2023 at 1:44 PM
    WagonHo!
    WagonHo! Member
    Donohoe, total chaos, deaver, doestch tech, flowmaster, American racing, ss lines, truflow, amsoil, powerstop...
    Jolly have you tried the Locktite or the lock washers on valve covers as of yet? I’ve got that task along with all the other oil seals, and gaskets. Going in to replace plugs, wires, coils and removal of fuel rails to r&r injectors. I want to remove all the peripherals but Once so trying to find a solution for this pesky leak as I’ve tried all the other temp nonfixes.
  7. May 11, 2023 at 2:25 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Not yet Sir. I hand tightened them snug for now until I find THIN washers, Do not want to use thick washers from HD /hardware store - as I may strip the head with not enough threads locking it, and do not want/need that.
  8. May 11, 2023 at 10:43 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    In RC world we use heat to break loose blue thread locked bolts....
    so using blue Loctite on anything on the engine would not be productive....
    Could use hi-temp Loctite ......but the surfaces are supposed to be etched for it to work best....
    and then touch em with a 75w solder iron and count to 20 before you break em again....
  9. May 11, 2023 at 10:50 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Threadlocking the bolt won't solve the issue, it's the rubber gasket shrinking over time. Very common on valve covers from that era, especially the 4.7
    I just check them from time to time. Tighten down a little as needed. All manufacturers got better at gasket/sealing systems over the years. Toyota was still better than most, even in the 90s
    Jolly Onion likes this.
