Loose water pump bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acparker12, Jul 17, 2022.
  1. Jul 17, 2022 at 9:15 PM
    acparker12
    acparker12 [OP] Well-Known Member
    Penns Valley, PA
    2014 MGM Tacoma TRD Sport 4x4
    Still figuring it out…
    I was underneath applying fluid film since it was cleaned from the other day and I had nothing better to do. Anyways while I was underneath I looked up and seen a bolt not tightened down the whole way, maybe sticking out 1/4” or so. Im pretty sure it was one of the 10mm bolts to the water pump that came loose. The one above the crankshaft pulley and located on the inner corner of the water pump on the drivers side. I tightened it back up but I’m curious as to why this happened. There’s no signs of a leak nor any noise from any pulleys, it doesn’t overheat or use any anti-freeze, truck runs great, reservoir tank is still at the same spot from when i bought it. Anyone ever have this happen before or know why it came loose? Thanks
  2. Jul 17, 2022 at 9:17 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Has the pump ever been replaced that you know of?
  3. Jul 17, 2022 at 9:34 PM
    acparker12
    Penns Valley, PA
    Not that I’m aware of
  4. Jul 17, 2022 at 9:36 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting I've never heard of one backing out, must have either gotten missed at the factory or the pump was replaced and it didn't get tightened.
    wilcam47 likes this.
  5. Jul 17, 2022 at 9:39 PM
    acparker12
    Penns Valley, PA
    That’s what I was hoping something simple as that, I plan on watching it to see if it comes back out again, truck just turned 96k the other day
