Loose Window
Discussion in '2nd Gen. Tacomas (2005-2015)' started by merv101, Nov 12, 2020.
  1. Nov 12, 2020 at 5:36 PM
    merv101
    merv101 [OP] Well-Known Member
    Grayson
    2008 Tacoma TRD Off-Road
    Mostly stock.
    Hey guys. My driver's side window seems to wiggle very slightly as I roll it up back and forth. If I take off the door panel, what should I be looking to move/tighten?
  2. Nov 12, 2020 at 5:41 PM
    DirtTaco
    DirtTaco Well-Known Member
    Your issue may be different, but both front windows in my truck got loose on separate occasions. For me it was the scissor mechanism that raises the window. There is a bolt where it pivots that loosened. I “think” it was a 10mm and I had to put the window at a particular height and reach the socket through a hole in the metal to access this bolt.
  3. Nov 13, 2020 at 6:52 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I had a loose window on my 06, watched this one about 8 times on how to remove side panel... finally figured it out
    There will be some bolts on the frame. Check with socket and extension.
    https://www.youtube.com/watch?v=yjhYKzE_yBg
    Muddinfun, drewnali and T4RFTMFW like this.
  4. Nov 13, 2020 at 8:16 AM
    DirtTaco
    Ya I guess that’s step one ha. Nice video.
  5. Nov 13, 2020 at 8:16 AM
    drewnali
    drewnali Well-Known Member
    Drew
    Florida
    2013 4X4 SSM TRD OR DCSB
    I don’t have a window to fix, or speakers to replace...but I’ve watched it eight times too.
    DiscoYaker likes this.
