Loosing coolant
Discussion in '1st Gen. Tacomas (1995-2004)' started by gabosox, Jan 31, 2010.
  1. Jan 31, 2010 at 4:57 PM
    gabosox
    gabosox [OP] New Member
    Jim
    Jasper, Georgia
    96 Tacoma 4x4
    I'm loosing coolant out the bottom of my bellhousing. None is showing up in my oil and no signs of a head gasket problem. Has anyone else experienced this? Is there a soft plug in the back of the block? Any help or suggestions would be appreciated.
    Thanks, Jim
  2. Jan 31, 2010 at 6:21 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Unlikely to have a plug in the rear. They have to be gotten to easily.
    You are losing coolant from the radiator?????
  3. Feb 1, 2010 at 4:35 AM
    gabosox
    Jim
    Jasper, Georgia
    96 Tacoma 4x4
    Not the radiator or any of the hoses. It's definitely coming out the bottom of the bellhousing. Guess pulling the engine will be next step.
    Jim
  4. Feb 1, 2010 at 5:57 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    But you do have to add coolant to the radiator, right?
    The radiator is down on fluid. Correct????
    If so, how much.....
  5. Feb 1, 2010 at 6:18 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Ever own a jeep? :p
    See the little gold triangle piece? That's the cylinder head rear cover. The gasket may be shot. See page three here.
    And the 5vz has several plugs on the rear of the motor.
    http://www.tacomaterritory.com/forum/showthread.php?t=128424
  6. Feb 1, 2010 at 6:25 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    Thanks for the pictures.
    I learned something new.
    Guess I'm used to working on my V-8.
  7. Feb 1, 2010 at 6:25 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The 3rz you can do without removing anything from the truck. The 5vz, yeah. Those plugs are behind the flywheel.
  8. Feb 1, 2010 at 12:11 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I thought the same thing.
  9. Feb 1, 2010 at 3:23 PM
    gabosox
    Jim
    Jasper, Georgia
    96 Tacoma 4x4
    Thanks for the pictures, I sure was hoping it may be just be a plug.
    Jim
