Loosing power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DMYOTA, Jun 28, 2017.
  1. Jun 28, 2017 at 5:38 PM
    DMYOTA
    DMYOTA [OP] Well-Known Member
    Dylan
    2008 black Tacoma SR5 4x4
    6in fabtech lift, bilstein shocks
    I have my 08 Tacoma SR5 4.0 V6 4x4 it has a 6" lift, sitting on 33" km2s and 4.56 gears. When driving on the highway with camping gear usually. Once it hit a hill the truck bogs down to 50mph and I can't get past that without constantly having the peddle to the floor. I feel like I should be getting more power but I'm not sure? This might be normal? Or what can I do to get more power?
  2. Jun 28, 2017 at 5:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds like you are beginning to hit the limits of what the engine is capable of at inclines. After you start adding armor, sliders, plate or tube bumpers all around, you will be forced to give it a ton of skinny pedal to keep the momentum going. I hate to say it, but the only solution to your troubles is to go with the TRD/ Magnuson blower. There is only so much power these 4.0's can put out naturally before additional help is required. your 6 inch lift does not help either, as I'm sure there is a lot of heavy bracketry and additional crossmembers there to add weight that prior were not there.
  3. Jun 28, 2017 at 6:09 PM
    DMYOTA
    Dylan
    That's what I was thinking too, it's just getting to heavy for that engine.. I'm going to be getting rid of the 6" lift hopefully by December I should have enough money in order to do a SAS. Not sure if that's going to take away any weight, might be close to the same if not more since it will be a Dana 44 and possibly 37s soo ya more weight..
    I need a Cummins haha
  4. Jun 28, 2017 at 6:18 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Our truck is kinda heavy for the little D44. Maybe if you ran 35s and wheel it gently. Lots of people in the SAS BS thread would probably strongly recommend something else.
    12TRDTacoma likes this.
  5. Jun 28, 2017 at 6:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Slap some new spark plugs into that bitch
    Kyitty, Torspd and stickyTaco like this.
  6. Jun 28, 2017 at 6:27 PM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    Could try a full exhaust redo headers,y pipe ,muffler try to pull out some more torque to help.
  7. Jun 28, 2017 at 6:28 PM
    Justinlhc
    Justinlhc Not looking for a relationship
  8. Jun 28, 2017 at 6:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Supercharger is the general consensus.
    Going SAS will keep you around the same weight if not add to it. You just need a blower plain and simple.
    Sandman614 and Murphinator like this.
  9. Jun 28, 2017 at 6:58 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I have the same problem with mine. Only in Colorado with the trailer. I'm turning 35s on my truck. Supercharger is on the list.
  10. Jun 28, 2017 at 6:58 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I'm running a shell, skids, bolt on sliders with fill plates, and a bumper/winch and can still pull a 5k lb travel trailer over mountain passes at 60mph...granted the truck is in 2nd and 3rd gear doing that (265/75/16 with stock 3.73 gearing). Sure, more power would be nice but the truck is perfectly capable if the OP isn't afraid to make it work some.
  11. Jun 28, 2017 at 7:06 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Supercharge it, you won't regret it :)
    :mudding:
  12. Jun 29, 2017 at 5:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Like Steve said. When is the last time that you replaced your spark plugs? What is your other maintenance like?
    Guarantee that your fuel filter is saturated and robbing power, unless you have upgraded to an external filter.
  13. Jun 30, 2017 at 1:28 PM
    DMYOTA
    Dylan
    It has all brand new spark plugs
  14. Jun 30, 2017 at 1:30 PM
    DMYOTA
    Dylan
    Plugs are new, and I had a full engine decarb and injections cleaning done as well
  15. Jun 30, 2017 at 1:35 PM
    DMYOTA
    Dylan
    Originally plan/thought was DANA 44, 4.56gears, arb air locker, chromoly, all that good stuff possibly running 37s.
    That was just the initial thought I'll be meeting with letzrolloffroad and a couple other guys within the next couple weeks to really develop a plan.
  16. Jun 30, 2017 at 1:43 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Is this hill at high elevation?
  17. Jun 30, 2017 at 1:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good for the injectors's flow percentages and atomization, but still doesn't address a saturated fuel filter.
  18. Jun 30, 2017 at 2:04 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    cummins swap
    Bebop and Aw9d like this.
  19. Jun 30, 2017 at 2:06 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    cats clogged up
  20. Jun 30, 2017 at 2:09 PM
    Bebop
    Nick
    Doubt it.
