Lopey Idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolverine69, Aug 20, 2016.
  1. Aug 20, 2016 at 3:24 PM
    wolverine69
    wolverine69 [OP] Member
    Ron
    My Little Green Mule
    Sony Explode Stereo system. Wheels from a 2010 Tacoma K&N Air Filter
    Hi
    I have a 2002 Pre runner 3.4l that has a real lopey idle. Like it has a heavy cam. Heavy vibration. It idles about 600 - 750rpm. It runs just fine. I can go from zero to top speed and back to zero no problems. from a stop if I floor it tires lite up just fine. Two different scanners show no codes, no check engine lights. Wires, spark plugs and fuel filters are new. throttle body is cleaned out mass air flow sensor cleaned. No engine modifications plain stock 3.4l.
    I have had 1 opinion/diagnosis of possible fuel injectors and or fuel pressure regulator
    Has anybody had this problem. Thx -Ron
  2. Aug 20, 2016 at 3:50 PM
    NateGB
    NateGB Well-Known Member
    Nate
    Los Angeles, CA
    04 Tacoma
    Icons, uniball upper arms, ome leafs, bilstein 5100
    I believe the 02 still had the idle air control valve. 03 and up doesn't have it. I'd check out the IAC valve first. There's a couple videos on YouTube about how to change one. I'd start by cleaning it out and reinstalling. If it changes the condition it may at least give you some help in progressing with the diagnosis.
  3. Aug 20, 2016 at 3:55 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    lopey idles are almost always because of an intake/egr leak. Bad maf reading is a fairly common cause aswell.
  4. Aug 21, 2016 at 11:33 AM
    wolverine69
    Ron
    Thanks Nate. I saw the video's on you tube. My local autozone had the gasket. Pulled the t-body, removed and cleaned the IAC and the passage to the t-body. Held my breath, crossed my fingers. Turned the key and still have the same issue. I did spray brake clean around the intake and t-body with no idle change. Any other Ideas? Any and all ideas are appreciated.
  5. Aug 22, 2016 at 8:14 PM
    Crikks11
    Crikks11 Member
    1997 Taco v6 4wd
    Did you manage to figure it out? Mine breaths fire once it's moving and the idle is steady but sometimes it just works in steps rpm goes to 800 and than down to 700-725. Slight vibration.
  6. Aug 24, 2016 at 10:44 AM
    Tyler Lacasse
    Tyler Lacasse Well-Known Member
    Tyler
    San Gabriel
    2002 Regular Cab
    I would check your vacuum lines and intake tube for cracks.
    Also, I would suggest cleaning your Mass Air Flow Sensor (MAF) with a MAF cleaner (don't use anything else). It is easy and quick to do and will also rule that one out too.
  7. Sep 10, 2016 at 11:26 PM
    Crikks11
    Crikks11 Member
    1997 Taco v6 4wd
    MAF cleaned running like a Swiss watch:)
  8. Sep 11, 2016 at 4:37 AM
    wolverine69
    Ron
    i replaced the mass air flow sensor and it didnt help.
