Losing brake fluid
Discussion in 'Technical Chat' started by Ray07tacoma, Mar 18, 2011.
  1. Mar 18, 2011 at 10:45 AM
    Ray07tacoma
    Ray07tacoma [OP] Well-Known Member
    Ray
    Phoenix
    07 Tacoma access 4x4
    turbo KN Filter 3" Lift Kit Rock Sliders TRD Skid plate ProComp 285/75R16, Removed. FJ Wheels w/ 265/70R17 Delay wiper switch 168xxx miles, engine lost compression at cyl 1. Replaced with pulled engine with 63k miles (non Turbo).
    4cyl, 5spd, 4x4, 86k miles.
    Have top off bake fluid in December then, a month/2000miles ago.
    Brake lites came on yesterday, ck fluid and it was at minimum again, so top it off again.
    Check for leak last month and again this morning, no wet spot or leak anywhere, master cylinder, wheels cylinders Frt/rear, no leak under clutch pedal. cannot find any sign of leaks
    Brakes works great but fluid useage does not seemed normal...
    any comments/suggestions??
  2. Mar 18, 2011 at 10:54 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Brake fluid levels in the reservoir will drop as the pads wear, but what you're seeing sounds excessively fast.
    Did you follow the hard lines through your entire truck looking for leaks?
  3. Mar 18, 2011 at 11:00 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Each brake cylinder has seal if one of them fails it will leak fluid, slowly but enough to make a level drop.
    You need to remove each wheel and apply brakes while truck is running to see leaks.
  4. Mar 18, 2011 at 11:36 AM
    Ray07tacoma
    Ray
    Phoenix
    Did follow the lines under truck and crawl under to visually inspect the back sideof rotor where the lines go in, and did not see and wet spot anywhere.
    I will have to take the wheels off to check each wheel cylinder, but I am skeptical as there is no sign of leak a all
  5. Apr 13, 2011 at 8:13 AM
    Ray07tacoma
    Ray
    Phoenix
    Well, finally found a wet spot in the cab under the clutch pedal.
    Brake Master cylinder Fluid reservoir also supply fluid to Clutch master cylinder, and that is the part that was loosing fluid.
    In this case the fluid was dripping behind the carpet, making it un-noticeable.
    Weekend project in the work.
  6. Apr 13, 2011 at 8:22 AM
    mjp2
    NJ
    Nice find, and good luck on the repair! :thumbsup:
  7. Apr 23, 2013 at 1:26 PM
    Chuckracer
    Chuckracer Member
    Thread Resurrection...looks like I may have the same problem with my '09 Standard Cab 4 banger 4x4...53,000 miles.
    How common is this?
    *edit* Apparently I have to replace my clutch master cylinder. Is this part rebuildable? Anybody done it? it can only be a leaking seal, right? :confused:
    Any of you wizards replaced that seal instead of the whole unit?
  8. Apr 24, 2013 at 6:42 AM
    Ray07tacoma
    Ray
    Phoenix
    It was a pain to get it back together.
    end up taking the pedal assembly in the cab apart to do it properly.
    Am sure that rebuild kit is available but not in local store, so replaced the unit.
  9. Apr 25, 2013 at 5:40 AM
    Chuckracer
    Chuckracer Member
    Thanks Ray. After reading your description of the job, I think I'll let my local trusted garage handle it.
    Thanks!
  10. Jun 13, 2021 at 2:43 PM
    Bfarmer
    Bfarmer New Member
    Bobby
    If you can't find the brake fluid leak check behind the clutch pedal.
  11. Jun 13, 2021 at 2:54 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Thats an old thread from 2013...
    Bishop84 likes this.
