Losing brake fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Jul 31, 2024.
  1. Jul 31, 2024 at 10:49 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pull back the dust boots on the wheel cylinders and see if there's brake fluid behind them. Or just squeeze and see if brake fluid comes out
    At 300k plus miles you could have blown wheels cylinders, leaking axle seals and a bad master cylinder. Keep looking
    Parkvisitor likes this.
  2. Jul 31, 2024 at 11:13 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Are we sure the master cylinder reservoir could go bone dry from brake pads wearing? My pads have very little life left (they're on my to do list before elk season), and my brake fluid level is still plumb full. I'm not really a believer that the fluid level would move significantly from pads wearing.
  3. Aug 1, 2024 at 12:04 AM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    That’s what I’m thinking too. Both my pads and shoes still have decent material on them. And if they were low, I don’t think it would drain the resivor that much. I mean it was empty empty.
    Red_03Taco[QUOTED] likes this.
  4. Aug 1, 2024 at 5:42 AM
    Red_03Taco
    Jerad
    Yea your booster seems a much more likely culprit.
    Pad wear theory ain't ringing true to me
  5. Aug 1, 2024 at 8:23 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    That's just the easiest answer for the light coming on from the fluid dropping some. I don't remember how much the fluid had dropped last time that happened to me, but I'm pretty sure the fluid float was sitting on the reservoir floor.
  6. Aug 1, 2024 at 8:31 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’ve seen cars with full metal to metal contact with the backing pads and rotors and not drop the reservoir low enough to have the light turn on. If it did it might have saved the owner some money haha
    Logans2001[OP] likes this.
  7. Aug 1, 2024 at 8:53 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Since you say all the lines are good, if the reservoir level has dropped to empty and you don't see a fluid stain on the inside of any of the wheels, I'm joining the bad booster voters.
    ControlCar and Logans2001[OP] like this.
  8. Aug 1, 2024 at 8:56 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah most likely your master is leaking into the booster....
    so now the fix is both a new master and a rebuilt booster.
    As far as the rear grease......only source would be rear bearings....
    if those seals are leaking it would be cascading out of the axle.
    maybe its just starting to fail and just a coincidence that the master is failing too.
  9. Aug 1, 2024 at 8:57 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Axle seals can leak slowly too. I had a slow leak when one of mine went. Makes a bunch of gunk in the drum from brake dust.
    Black97v6MT likes this.
  10. Aug 1, 2024 at 9:08 AM
    O'Silver_Taco
    MD
    Your worst mistake would be to run the diff dry.....
    those salvage start at $1200 to $1500.......if you can even fine yours...
    So I'd be tempted to pop that plug and top that off to be safe.
  11. Aug 1, 2024 at 9:14 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Well it’s in the shop now. I don’t have the time, space, or tools to do the axel seals myself and I’m having them take care of the brake fluid issue too. I appreciate all the helpful replies and I’ll update this thread when I get it back.
  12. Aug 1, 2024 at 9:16 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    I was curious why that gunk was so thick. I don’t recall grease like that being apart of the axel assembly unless I’m mistaken.
    Is that thick black grease just gear oil mixed with brake dust??
  13. Aug 1, 2024 at 9:23 AM
    O'Silver_Taco
    MD
    Means you've probably been stopping using almost all front brake....
    that may of been what did in the master...
    5vz w/ 4X4 is a pretty heavy vehicle.....
  14. Aug 1, 2024 at 9:48 AM
    O'Silver_Taco
    MD
    Let us know what they find and how much...
    It took over a $100 in specialty tools.....dozen videos......6mos planning....and all day to do my rear seals...
    The booster is a real concern......I've seen them as cheap as $200, and some that were almost $900.....
    ControlCar likes this.
  15. Aug 1, 2024 at 10:23 AM
    #35
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Any brake fluid that gets past the brake cylinder dust boots (the part you see when the drum is removed) first gets past the seals that are inside the cylinder and on the two pistons (the parts you don't see until you disassemble the cylinder).
  16. Aug 1, 2024 at 4:52 PM
    #36
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Clean or replace the rear diff breather too!
  17. Aug 1, 2024 at 4:57 PM
    #37
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    What’s crackin?
    How is that diff breather plug looking?
  18. Aug 1, 2024 at 4:58 PM
    #38
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Exactly.
  19. Aug 1, 2024 at 5:33 PM
    #39
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah the grease in the bearings won't get outside of them unless it's flushed out by gear oil from the diff.
    IDK about pad / shoe wear running the brake fluid reservoir dry - that would be a poorly designed system to not have a safety factor built in. Again lots of people will get down to metal on metal on their brakes and not run the reservoir dry and have the light come on - just google some videos of mechanics making jokes about customer mistakes they find.
  20. Aug 1, 2024 at 5:38 PM
    #40
    MadNachos
    I have never seen an OE brake system where the low fluid warning light won't go on before the pads are toast. People get the light and add fluid 99% of the time I would assume. You should only replace brake fluid, never add it.
