Losing brake fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Jul 31, 2024.
  1. Aug 5, 2024 at 7:46 PM
    #61
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah if you don't go all the way to bearing....its maybe thirty min each side...kindergarten work....
    But the correct way ......that is with all the grease pushed out of the those big ass bearings....
    is too do the full monty.....that's couple / three hours each side.....and another $200 in parts (outer seals/bearings/lock rings)
    and thats only if you've done it before...........otherwise double the time
    thats reason they charge $1000 + to do that...
    MadNachos likes this.
  2. Aug 5, 2024 at 8:10 PM
    #62
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I misread and though it included wheel bearings in addition to seals. You're right without the bearings. In my experience the press work for the bearings is very tedious
