Losing coolant can't find the leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by 860yota, Feb 28, 2017.
  1. Mar 3, 2017 at 4:45 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Here's what mine was doing.......not-so-secret project going on behind the pulley
    Xbeaus and FirstTimeFirstGen like this.
  2. Mar 4, 2017 at 10:11 AM
    860yota
    860yota [OP] Member
    Its not overheating at all...now today it wont start just cranks and cranks but its dont fire up
  3. Mar 4, 2017 at 10:19 AM
    860yota
    860yota [OP] Member
    The truck is throwing a bank2 knock sensor and a temp coolant sensor neither of wich would stop it from running...as far as I know just frustrating just got the pressure tester and now it wont run hahaha
  4. Mar 4, 2017 at 10:20 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That's gotta be the slowest drip out of the weep hole on a water pump I've ever seen, to be able to build up like that. Or I haven't seen very many water pumps weeping.
    FirstTimeFirstGen likes this.
  5. Mar 4, 2017 at 10:21 AM
    cruiserguy
    Elijah
    SEKS
    Won't a bad knock sensor keep it from firing up?
  6. Mar 4, 2017 at 10:22 AM
    cruiserguy
    Elijah
    SEKS
    Maybe it's a different sensor that keeps it from firing up, I don't memba off hand.
  7. Mar 4, 2017 at 10:24 AM
    cruiserguy
    Elijah
    SEKS
    If oil is leaking into cooling system, it might not show 'steam cleaned' plugs. But if coolant is leaking into the cylinder, yeah definitely would.
  8. Mar 4, 2017 at 10:29 AM
    860yota
    860yota [OP] Member
    i wish i was just growing a stalagmite like t@co_pr3runn3r is haha
  9. Mar 4, 2017 at 10:31 AM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Rodents have that effect as well. Hope I'm wrong
  10. Mar 4, 2017 at 10:33 AM
    860yota
    860yota [OP] Member
    rodents did what now?
  11. Mar 4, 2017 at 10:37 AM
    10MGM
    2010 AC MGM 4x4
    Rodents are attracted to wiring insulation. Knock sensor harness is on the menu. Just sayin.
  12. Mar 4, 2017 at 10:51 AM
    860yota
    860yota [OP] Member
    But would a knock sensor stop it from running..i know it retards the timing when its in limp mode but it should still run right?
  13. Mar 4, 2017 at 11:11 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Granted you seem to be leaking a fair volume but there is one spot not yet mentioned.
    A leak at the "coolant bypass tube" where it bolts to the block can leak and go undetected. The forward tube flange is sealed with RTV, no gasket or o-ring. It can leak and puddle under the intake between the heads. Many times the coolant cooks off at a faster rate than the leak. A bad leak will trickle down the back of the block from a sheet metal plate that is difficult to see, until it's bad enough to drip to the ground.
    It's a bunch of work for a little smear of sealant.
    Leak at yellow arrow, "plate" seen at top center.
  14. Mar 4, 2017 at 12:43 PM
    860yota
    860yota [OP] Member
    Well i finally got something....the timing belt jumped and it looks like the waterpump might be my problem
  15. Mar 4, 2017 at 1:35 PM
    #35
    860yota
    860yota [OP] Member
    Thanks Dirty Pool i will remember to address that when change the knock sensor out
  16. Mar 4, 2017 at 6:35 PM
    #36
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    If your knock sensor is bad it will go into limp mode. Could be wiring. Wonder how the timing belt skipped? That's not common. Maybe switch to that Toyota red coolant. Not that it's a need, the 3.4 just likes it
  17. Mar 4, 2017 at 11:13 PM
    #37
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    I was losing coolant for the last month. Ended up being the radiator. The way I found out was because I added some head gasket sealer thinking it was a head gasket. I noticed residue around the tank/rad interface at the top of the radiator. Replaced hoses and thermostat at the same time.
  18. Mar 5, 2017 at 10:47 AM
    #38
    860yota
    860yota [OP] Member
    Well this is my new update....the cam bolt on the driver side broke off..my tech thinks it happened because of a bad power steering pump
  19. Mar 5, 2017 at 10:52 AM
    #39
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Why does he think that? I don't get the correlation between the 2.
  20. Mar 5, 2017 at 11:27 AM
    #40
    860yota
    860yota [OP] Member
    He told me he had come across this before while at a Toyota shop a few years ago...all the belts have been shaved down even the timing belt is smoothed out...and the pump wont budge..Do you think it could be something else?
