Losing coolant very quickly
Discussion in '4 Cylinder' started by TSSFiveSpeed, Aug 18, 2023.
  1. Aug 18, 2023 at 12:11 PM
    TSSFiveSpeed
    TSSFiveSpeed [OP] Well-Known Member
    Damion
    ar kansas
    5 speed taco pimped out
    Cold Air Intake, Shift Knob, Radio, URD Short Throw Shifter Kit, Pioneer 6 1/2 speakers, sound deadened, LED headlights, LED tails, 4 inch lowering blocks, bilstein rear shocks, Cooper A/Ts, oil catch can
    My 2TR motor seems to be drinking coolant every time I put more in. There is nothing wrong with the head gasket, no leaks, (from what I can see) and I just recently changed the water pump and thermostat. It overheats sometimes but not to the point where it shuts off it just runs really hot for a minute and cools off when I drive. I hate having to buy coolant over and over and was wondering if there is any more places where coolant could be leaking or something?
    TacoSR523 likes this.
  2. Aug 18, 2023 at 1:00 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Is it puking the coolant out into the overflow reservoir? Or the coolant is simply disappearing?
    also what year is your truck? The 05-11ish year models came with a plastic coolant bypass pipe that may be leaking slowly
    Steves104x4 and TacoSR523 like this.
  3. Aug 18, 2023 at 1:04 PM
    TSSFiveSpeed
    Damion
    ar kansas
    Mine is an 05. And no, it doesn't really spit it back into the reservoir. It more or less just stays the same, but the coolant gets super hot sometimes and bubbles but it hasn't done that in 2 weeks bc I flushed the system when I changed the thermostat and water pump.
  4. Aug 18, 2023 at 1:10 PM
    BassAckwards
    You can see it bubbling in the reservoir?
  5. Aug 18, 2023 at 1:15 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Bet that motor is toast.....you did a leakdown test?
    Nessmuk likes this.
  6. Aug 18, 2023 at 1:19 PM
    TSSFiveSpeed
    Damion
    ar kansas
    Lol I should've explained a little first, it did because I put water in it when I was out of town and had no other option. Was on the highway for 4 hours so I guess that's just what it did. But after I flushed it and everything it hasn't done that since. Pretty sure it was just the water.
    Anyway, where is this bypass pipe located?
  7. Aug 18, 2023 at 1:19 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Is there any coolant on the ground or engine? Or does it smell like it?
    There is an o-ring at the very top of the pump housing to the block. My replacement o-Ring was defective, and leaked there. Took two weeks to trace
    Also, invest $10 in one of those new funnel systems that let you run all the bubbles of air out.
  8. Aug 18, 2023 at 1:21 PM
    TSSFiveSpeed
    Damion
    ar kansas
    Not that I can see no, which is really odd to me and i know for sure nothing is wrong with the head gasket. I have one of those funnel systems too, i bleed it like every 2 days it's getting really annoying. I bleed it for like 30 minutes to make sure no air is in it at all
  9. Aug 18, 2023 at 1:24 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    How are you checking the Headgasket?
  10. Aug 18, 2023 at 1:26 PM
    TSSFiveSpeed
    Damion
    ar kansas
    No oil in coolant, and no coolant in oil drained it about a week ago. And I have been checking the dipstick every day or so, put oil on my finger and it doesn't stink of coolant. Pretty soon I'd like to do a compression test to make sure but haven't found the time.
    On a side note there is no smoke, it doesn't not seem to run any worse than it did before it idles great and stays at one temp when it has coolant.
    HondaGM[QUOTED] likes this.
  11. Aug 18, 2023 at 1:30 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    So if im reading right..its losing coolant ,but it has no external leaks..gotta be burning it
  12. Aug 18, 2023 at 1:32 PM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    May not be mixing coolant and oil, but another headgasket failure mode is letting combustion gases bleed into the water jacket and push coolant out of the reservoir. Leaving hot gas pockets that allow areas of your engine heat up enough to boil it.
    Or it may be burning it. Pull the plugs and see if any cylinders/banks look exceptionally clean. Followed by a leakdown test. And double check that your thermostat works and your rad isn't clogged up
    TacoSR523 and TSSFiveSpeed[OP] like this.
  13. Aug 18, 2023 at 1:34 PM
    TSSFiveSpeed
    Damion
    ar kansas
    Odd. It could possibly be the bypass pipe that BassAckwards was talking about though. It's close to 230k miles on the motor what do i expect lol
    TacoSR523 and HondaGM[QUOTED] like this.
  14. Aug 18, 2023 at 1:42 PM
    TSSFiveSpeed
    Damion
    ar kansas
    Thanks for the info. Will be doing that later this week. I might replace the rad too, as it's almost 20 years old. Along with that bypass pipe and anything else I can think of
  15. Aug 18, 2023 at 1:47 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Zerksees likes this.
  16. Aug 18, 2023 at 1:56 PM
    risethewake
    Will
    '15 MGM Sport AC
    Not sure if it's your daily driver, but I'd try not to drive it at all until you get the cooling issues figured out. Uneven coolant flow and gas pockets can/will warp metal and cause a ton more damage, up to and including grenading the engine.
  17. Aug 18, 2023 at 2:09 PM
    TSSFiveSpeed
    Damion
    ar kansas
  18. Aug 18, 2023 at 2:10 PM
    TSSFiveSpeed
    Damion
    ar kansas
    Yeah it's my daily. I have a BMW but I'm in the middle of fixing that right now so I can't afford mine blowing up on me. I am about to go peak around the engine where the bypass hose is located to see if I see any leaking or whatnot
  19. Aug 18, 2023 at 2:22 PM
    BassAckwards
    Driver side under the intake manifold
  20. Aug 18, 2023 at 6:16 PM
    TSSFiveSpeed
    Damion
    ar kansas
    well here is the spark plugs for you. They looks kind of normal to me besides being really dirty. No clue why they are so dirty I changed them about 5k miles ago maybe a little more. Does one stand out at all?
