losing coolant
Discussion in '1st Gen. Tacomas (1995-2004)' started by alasek, Jun 5, 2019.
  1. Jun 5, 2019 at 3:25 PM
    alasek
    alasek [OP] Member
    I have a 2000 Tacoma 3.4 and I did the head gasket job and I still losing coolant
    No puddles or in the engine
    Somebody told me it could be the oil cooler but I don’t wanna keep throwing more money in it
    Anybody with the same problem
  2. Jun 5, 2019 at 4:06 PM
    Indy
    Indy Master of all I survey.
    Is your oil milky looking? If you run it without the radiator cap, does it look like it's boiling in the radiator? Any white smoke?
  3. Jun 5, 2019 at 4:17 PM
    alasek
    alasek [OP] Member
    Nop
    Like I said no puddles or milky oil or overheating
  4. Jun 5, 2019 at 4:20 PM
    Indy
    How much coolant have you lost? In can only go so many places.
  5. Jun 5, 2019 at 4:25 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Any white powder along the top of the radiator?
    Any chalkyness around the right front (facing the engine)?
    Any water in the passenger floorboard?
    What temperature is the truck running at?
    cruiserguy, Wulf and GQ7227 like this.
  6. Jun 5, 2019 at 6:11 PM
    alasek
    alasek [OP] Member
    Just a little bit every day but like I said no puddles
  7. Jun 5, 2019 at 6:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @OneWheelPeel just gave you a list of suggestions; none of them apply to you?
    I replaced my radiator because it had a leak -
    Here you can see the long crack in the plastic -
    cruiserguy and OneWheelPeel like this.
  8. Jun 5, 2019 at 6:18 PM
    alasek
    alasek [OP] Member
    Yeah like I said no puddles
    That’s why I went go ahead and do a head job on it and the machine shop checked the heads for cracks and they came out good but I still have the same problem
    Losing coolant and I don’t know where is going
  9. Jun 5, 2019 at 6:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    We got it, no puddles.
    But I'm referring to maybe any dried coolant anywhere on top? It could be seeping out and burning off hence why you won't see any puddles. You'll be left with a residue though.
  10. Jun 5, 2019 at 6:24 PM
    alasek
    alasek [OP] Member
    Ok
    Yeah I don’t see anything
    I thinking about throwing one of those engines that come fro japan
    The only problem is that I spent like $700 bucks already in this existing engine
  11. Jun 5, 2019 at 8:52 PM
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    Can always throw a dye in the coolant, run it for a few days and look for obvious staining. Taletail for leaks.
  12. Jun 5, 2019 at 9:20 PM
    Glamisman
    Glamisman Well-Known Member
    as mentioned above... it could be anywhere. In my experience mysterious leaks are at either the thermostat bypass tube under the lower intake, core plugs on the back of the block or seepage and consumption at the upper intake to head. Did you do the work?
    Wsidr1 likes this.
  13. Jun 5, 2019 at 9:23 PM
    Wulf
    rock raisin
    Did you have the heads magnafluxed and machined? You could have a cracked head and be burning the coolant off.
  14. Jun 6, 2019 at 3:59 AM
    04TRDV6
    04TRDV6 Well-Known Member
    Lynn
    Houston, TX
    2004 TRD V6 XtraCab
    What's the condition of the cap? The seal on mine was bad (old) and I was losing coolant but no noticeable staining. Topped it up with distilled water, new cap and problem solved.
    CouchlessPotato likes this.
  15. Jun 6, 2019 at 6:16 AM
    fenmik
    fenmik Well-Known Member
    Nova Scotia, Canada
    2019 Double Cab TRD Sport.
    You could also check your water pump. It could be leaking a little bit and evaporate from the heat so you would not notice any puddles. Just a thought.
  16. Jun 6, 2019 at 6:21 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    The pressurized cap raises the boiling point of the coolant. If the cap is not sealing correctly your coolant will boil out of the top of the radiator and you'll never see a puddle. I would change the cap and see if that solves the issue
    vettehigh and cruiserguy like this.
  17. Jun 6, 2019 at 7:50 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Do you smell coolant at all?
  18. Jun 6, 2019 at 8:07 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    This is what I was thinking. Dont remember the member, but he had a slow leak from his weep hole. Wasnt enough to create a "puddle" but once he pulled the timing cover and looked, it was obvious.
  19. Jun 6, 2019 at 8:25 AM
    OneWheelPeel
    Phoenix, AZ
    Where do you think Bigfoot lives?
