losing MPG with a CAI?
Discussion in 'Performance and Tuning' started by ez_money08, Jan 7, 2009.
  1. Jan 7, 2009 at 6:02 PM
    ez_money08
    ez_money08 [OP] EZ's Black Taco
    San Diego
    Blacked out '08 Tacoma SR5 4X4 4.0L
    3 1/2" Icon coilovers, wheelers 2" AAL's, Total Chaos UCA's, diff drop, carrier bearing drop, TRD Cai, Magnaflow exhaust, halo projector headlights, L.E.D tail lights, Blue gauge light mod, Satoshi grille, Hella 700's with H.I.D conversion behind grille, herculiner on rockers and rear bumper, lighted buggy whip mount in bed
    I recently installed a TRD CAI. The increase in Horsepower is good, but my MPG went to hell. any suggestions on what might be going on?
  2. Jan 7, 2009 at 6:03 PM
    roggs01
    roggs01 Roggs01
    Surprise, AZ
    16 TRD Sport
    Predator steps,Method NVs, 285-70-17 KO2s
    Are you driving with a heavy foot?
  3. Jan 7, 2009 at 6:05 PM
    carolinyens
    carolinyens Creedmoor Connections
    Durham, NC
    08 X-Runner
    TRD CAI, TRD SS, Toyota All Weather Mats, Eagle Eye Halos, NST Crankshaft Pulley, ScanGauge II, TRD Shiftball, TRD SeatCovers, WeatherTech Vent Visors, 20% tint, DTLT's and NST pulley combo.
    You gotta be punching it all over the place. I know I had this problem when I first had this installed. But once you get used to it, it will help a little with mpg but dont expect a crazy increase in it.
    Add this to your modifications
  4. Jan 7, 2009 at 6:19 PM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    you must be standing on the throttle pedal alot bc my truck is like that, but driving easy u should get relatively good mpg, but yours is a 4.0 so it might be different from my 3.4
  5. Jan 7, 2009 at 11:08 PM
    ez_money08
    San Diego
    not really driving with much of a heavy foot. i will punch it now and then though cuz it sounds good. planning on a magnaflow exhaust and chip to recalibrate the speedo on trans shift points next
  6. Jan 7, 2009 at 11:13 PM
    dunkhi
    dunkhi CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    did it give u a good sound?
    and did u really feel the hp gain?
  7. Jan 8, 2009 at 12:20 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    http://fuelsaving.info/power_economy.htm
    Letting more air in means you can use more fuel, which is what's increasing the power.
  8. Jan 8, 2009 at 12:36 AM
    nurseboy
    nurseboy Well-Known Member
    Jan
    Riverside, Ca
    is right. the more air you suck into the motor, the more fuel is needed. more HP but burn more gas.
  9. Jun 22, 2009 at 6:30 PM
    sjdm4211
    sjdm4211 Member
    Tennessee
    Toyota Tacoma 2WD 2.7L
    I totally disagree, Less restriction means the engine doesn't work as hard sucking air in. You won't have to burn as much gas to get the same amount of HP out of the engine as before installing the CAI. Same thing goes for exhaust.
    The OP's problem is obviously a lead foot.
    My problem with a CAI is paying $250 plus to get 7 more HP out of my 2006 2.7. If I am only getting 7 HP how much improvement to my MPG could I possibly get.
  10. Jun 25, 2009 at 10:34 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    1. You may have gotten dirt on the MAF element which could throw off your mpg. Try cleaning it with electrical cleaner.
    2. Inferior CAI's will disrupt the flow of air in a manner that throws the MAF a curve ball and could cause bad mpg.
    In theory, you should be getting better mileage with the maf because of the increase in efficiency.
