Losing oil, possible valve cover gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mike06toyota, Mar 11, 2024.
  1. Mar 12, 2024 at 8:29 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    You have to realize that if you are leaking oil into your spark plug holes with leaking valve cover gaskets you are not going to necessarily have useful information from exhaust smoke until you get that fixed.
    Check your radiator and make sure you don't have a milkshake.
    The only other recommendation that is likely worth following would be to do a compression test on your cylinders. If you have a good compression test, and you can't find oil on the outside of the engine anywhere then the most likely culprit is going to be a valve cover gasket (which you already confirmed is bad) and possibly a PCV valve. I'd replace both if I were you (following a good compression test).
    Then after you fix the oil burning in your cylinders, then you can move downstream and address your exhaust/catalytic converter issue.:)
  2. Mar 12, 2024 at 8:52 AM
    Mike06toyota
    Mike06toyota [OP] Well-Known Member
    Santa Clarita
    06 PreRunner TRD Sport
    K&N Intake Flow Master
    Yes sir, I got the new pcv valve in. I’ll try to get that compression test done.
    I am actively monitoring the oil, as of my high end consumption from the oil changes it would look like I’m burning 1 quart every 1650 miles. I’ll monitor this with the dipstick and once I can get that compression test done I’ll report back.
  3. Mar 12, 2024 at 10:31 AM
    Mike06toyota
    Santa Clarita
    Also radiator looks nice and pink.
