Losing oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justinstoytac, May 11, 2019.
  1. May 11, 2019 at 12:59 PM
    justinstoytac
    justinstoytac [OP] Active Member
    Justin
    CO
    Toyota Tacoma TRD Off-Road
    Weather-Tech Floor liners, Weather-Tech Rain Guard, Cover King Set covers, 3M Window Tint, Tube Steps, Roof Rack Future Mods: Plasti dip Grill and badges Future Up-grades: Bilstein 5100 Hight adjustable set at 2.5", Bilstein 5100, Multi-leaf spring pack Leaf progressive 1.5" lift
    I have a question about engine oil.
    I have 2013 4.0 4x4 trying to find a oil brand that stays in the engine and doesn't seem to go out the tailpipe. There is NO leaks I have checked and checked and checked. I'll change my oil and make sure its full. About 1k miles I'll be 2 to 2 1/2 quarts low. I'll re-add same thing. What engine oil do you use and have you noticed the same thing.
  2. May 11, 2019 at 1:03 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You've got a bigger problem that the type of oil being used.
  3. May 11, 2019 at 1:04 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    How many miles on your truck? If it’s burning oil your can try a high mileage oil. Helps minimize leaks to a point. Try changing the pcv.
  4. May 11, 2019 at 1:05 PM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    If you've got no external leaks... sounds like a valve or ring problem. Any smoke from tail pipe?
  5. May 11, 2019 at 1:10 PM
    justinstoytac
    Justin
    CO
    No smoke yes mind is blown I dont know where its going
  6. May 11, 2019 at 1:10 PM
    justinstoytac
    Justin
    CO
  7. May 11, 2019 at 1:14 PM
    UKJON
    UKJON Well-Known Member
    :popcorn:
    whatstcp likes this.
  8. May 11, 2019 at 2:25 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Have a friend drive behind you to confirm that you're not burning it. It might be just faint enough where you can't see it from the rear view mirror, because it mixes with the outside air enough to dilute the smoke.
    PCV faulty or clogged?
    12TRDTacoma and TRDBROPRO like this.
  9. May 11, 2019 at 2:26 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    A better question is what kind of oil are you using so we can stay away from it.
    edit: I did have a motorcycle once that had this problem and was not common AT ALL to others with the same model.
    I got rid of it. It was competently diagnosed to rings that never sealed in 1 cylinder.
    TRDBROPRO and Sig45 like this.
  10. May 11, 2019 at 3:06 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Burning 2+ quarts of oil per 1,000 miles sounds like an awful lot to not see it at the tailpipe. o_O
  11. May 11, 2019 at 3:20 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    I know. I'm just trying to think of anything at all that might help. Scratching my head.
    He's insisting there's no leaks and none out the tail pipe. l believe he's checked. But just seems so unlikely that one would loose that much oil without a telltale sign somewhere. :notsure:
  12. May 11, 2019 at 3:38 PM
    BKinzey
    Beauford
    Hollywierd, CA
    OK, longshot.... What oil are you currently using, brand & weight?
  13. May 11, 2019 at 3:41 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Is everything else up to date maintenance wise? All filters are replaced per the service schedule, etc?
    Have you ever had any previous engine damage or harsh events like driving in really dusty areas without the air filter in place? (or worse - are you using a "performance" air filter that maybe didn't catch fine debris?)
  14. May 11, 2019 at 4:25 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Start with the basics .
    Do a compression test so you have a baseline reading.
    And go from there.
    TOMB
  15. May 11, 2019 at 4:30 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I'm not sure how long this has been happening but I would be surprised if you did not have a check engine if it was burning. You should have poisoned the catalytic converters by now. The check engine light does work? You may have a running leak, better start looking. My '13 doesn't use a drop at 61k,5w-30 synthetic oil and Toyota filter every 5000 miles.
    BillsSR5 likes this.
  16. May 11, 2019 at 6:30 PM
    D.A.R.
    D.A.R. Well-Known Member
    2015 TACOMA TRD PRO
    Look at your radiator cap and overflow bottle for signs of oil.You may have a leaking head gasket.See if the exhaust smells sweet like coolant.
  17. May 11, 2019 at 7:04 PM
    justinstoytac
    Justin
    CO
    No signs of oil in radiator or reservoir.
    Exhaust dont smell sweet.
    I would say it's more recent that I have noticed.
    Like the last 30k miles. Air filter and oil filter are clean I change oil and filter every 5k and air every 2.5k due to the dry dust conditions I live and drive in. Sometimes more.
    I have tried. 5w30 each one of these varied from 1 to 2.5 list beginning worse to better.
    Moble 1
    Pennzoil
    Valvoline
    Quaker State
    Changing oil tomorrow going to be using
    castrol gtx
  18. May 11, 2019 at 7:12 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Do this.
    k5driver likes this.
  19. May 11, 2019 at 7:13 PM
    Troyken
    NY
    I guess a compression test dry and wet will be the next step. It's probably too late now but I wonder if a used oil analysis would show lots of silica in the oil from dust in the intake air. You are certainly in severe duty territory if you have that much dust in the air.
  20. May 11, 2019 at 8:02 PM
    justinstoytac
    Justin
    CO
    Welcome to southern NEw Mexico.
    I am gonna attach a gopro at the wheel well aimed at the exhaust to see if I can see any white smoke.
    Just to get a closer look because i am unable to see it while driving. I'll have a friend rev up the engine while I stand by the exhaust and smell it to see and do a compression test. (But if I still have good enough power to tow 5k+ trailer) idk
