Losing oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justinstoytac, May 11, 2019.
  1. May 11, 2019 at 8:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    PCV valve is what I would suggest checking/clearing or replacing if totally defective.
  2. May 11, 2019 at 8:09 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Do you have emissions testing in your state? If you’re burning that much oil it would show up for sure. Even if it’s not mandatory that may not be a bad idea to find a shop with an emissions analyzer.
  3. May 11, 2019 at 8:16 PM
    justinstoytac
    justinstoytac [OP] Active Member
    Justin
    CO
    Toyota Tacoma TRD Off-Road
    Weather-Tech Floor liners, Weather-Tech Rain Guard, Cover King Set covers, 3M Window Tint, Tube Steps, Roof Rack Future Mods: Plasti dip Grill and badges Future Up-grades: Bilstein 5100 Hight adjustable set at 2.5", Bilstein 5100, Multi-leaf spring pack Leaf progressive 1.5" lift
    No emissions test here.
    I'll check the PCV.
    And no the check engine light is not on
    Thank you all for your suggestions
  4. May 11, 2019 at 8:35 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This doesn’t make sense. You say for the last 30000 miles you have been using 2 plus quarts of oil every 1000 miles. That’s 60 quarts of oil. If it was leaking anywhere the underside of your truck would be covered in oil, you’d have oil everywhere. If you are burning 2 quarts or so of oil every thousand miles you would have quite noticeable smoke coming out your tailpipe. If the underside ain’t covered in oil then you are burning it. Leaking or burning it, those are the only two options. Sumtin jus ain’t right. Makes no sense. Let us know when someone figures it out.
  5. May 11, 2019 at 9:13 PM
    ronmanfredi
    ronmanfredi Member
    Ron
    Leander Texas
    2013 Metallic Gray SR5 Prerunner
    Bed Cover
    Change the PVC valve and see what happens. Running a compression test won't necessarily show oil consumption if all cylinders are the same. Take it to a quality shop and have them doing a "cylinder leak down test". This will tell you where the oil is going, (valve seals or piston rings and in what cylinders)
  6. May 11, 2019 at 9:18 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    If you are changing your AIR FILTER every 2500 miles then we need to know more about this.
  7. May 11, 2019 at 10:14 PM
    justinstoytac
    Justin
    CO
    I am sorry guys maybe it was unclear let's start from the beginning brand new oil change with filter and air filter i put 5qts in 1k later I am down x amout of qts depending on the oil I have said I tried as per the manual says 5qts is all that is need
  8. May 11, 2019 at 10:16 PM
    justinstoytac
    Justin
    CO
    And it stays there I'll add to fill back up then 1k later I am back to x amout low again
  9. May 12, 2019 at 4:54 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    l think we all understood what you said initially. You were clear about what was going on. .
    We're all just racking our brains trying to come up with what's happening with your oil.
  10. May 12, 2019 at 5:34 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I know it's a completely different vehicle and motor but my Prius had the exact same problem (very common for priuses to start burning oil around 100k). No symptoms, just burned a quart every 1k mile. Hopefully you get it figured out op
  11. May 12, 2019 at 5:36 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    The pcv is meant to take crankcase fumes and re-burn them instead of venting to the atmosphere like they used to. If he has a huge amount of blow-by, that would clog up the pcv and intake system to the point he would have symptoms I would think. Another very remote possibility is leaking injectors with gas diluting the oil to the point it burns readily as the oil rings can't control it. Without compression data otherwise it may be that this engine is worn out from hard use. It may be that he has an unlikely but possible manufacturing defect in the rings ,pistons , cylinder wall finish or something. I wonder if the power train warranty covers this?
  12. May 12, 2019 at 6:31 AM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    I’ve read it’s common with some high mileage Priuses but not sure how common.. as my Prius w/ 165k miles doesn’t burn a drop of oil at 7500 OCI.
  13. May 12, 2019 at 7:52 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Here's an easy test you can do today. Get a buddy to follow you in another car.
    From a stop or low mph, punch it and run it through first and second. If you get smoke on acceleration, you have one or more bad rings.
    From a steady 50 or 60 mph, manually shift down to 3rd gear so that the rpm's rise and slow the truck down. If you get smoke on deceleration, you have one or more bad valve guides.
    Monkeybutt2000 likes this.
  14. May 12, 2019 at 9:10 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    This right here ^^ Pull a couple of plugs also.
  15. May 12, 2019 at 9:19 AM
    #35
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well there is part of the problem. You take 5.5 quarts not 5 quarts and you are under filling the oil right from the get go by half a quart.
  16. May 13, 2019 at 8:43 AM
    #36
    Rick's 2012
    Rick
    Costa Rica
    Stock
    Hello..lo..lo..lo...lo..lo...........???
  17. May 13, 2019 at 8:48 AM
    #37
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    You dont have an oil problem. They are all about the same nowadays
  18. May 13, 2019 at 10:54 AM
    #38
    Rick's 2012
    Rick
    Costa Rica
    Stock
    The OP says he's losing 2 - 2 1/2 quarts in 1,000 miles of driving. That's a lot of oil!
    I'm not loosing any at all between oil changes.
    l think that there is a problem somewhere.
    SR-71A likes this.
  19. May 13, 2019 at 10:55 AM
    #39
    TacomaSport86
    Yea its not the brand of oil though!
  20. May 13, 2019 at 1:43 PM
    #40
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Nah, I fill with 5qts as do others. Brings me right up to full on the oil dipstick
    SR-71A likes this.
